375W is its maximum possible constant output, your probably not using that much, but your best bet is to wire it up to the battery, cigarette lighter sockets arent designed for much current load.
If its worked without heat/voltage drop problems so far then you might get away with it, but if u plan on using it long term then hard wire it in.
LinkBack URL
About LinkBacks
) that the cigarette lighter cap lists 12v/120w max! Does this mean I'm screwed?
