Results 1 to 3 of 3
Thread: options to hook up inverter?
    May 2004
    hi, i m in a process of hooking up my inverter.
    I can either wire directly to the battery or use the cigarrete lighter . i understand hard wiring to the battery is better, but is it worth it? drilling a hole on the firewall is alot of work for me. if i use the lighter plug, does it have any disavantages?
    I have a 175w inverter. thanks for the help.
    PS. the lighter is connected to a 20a fuse.
    Jun 2004
    Upstate New York
    Blowing the fuse is the biggest disadvantage. I plugged mine into the cigarette lighter then tried to use the lighter...end result= no more audio until I replaced the fuse (at the end of my 45 minute ride to work, good thing I was halfway there when it blew). Next purchase for the car PC...an Opus P/S, power inverter's not worth the hassle for me.
    Variable Bitrate vcbb5's Avatar
    Aug 2002
    Kansas
    Go to the battery (good clean power is a must). Also, i dought a 175 watt inverter will be powerful enough for the average carputer (again, good clean power is a must).
    My Mazda 3s
    My Mazda 3s on Car Domain
    [||||||||||||||||||--] (90%)
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 09:04 AM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  3. Help Eliminating Inverter Noise - Options
    By prospero in forum General Hardware Discussion
    Last Post: 04-21-2004, 01:37 PM
  4. How do I hook up an inverter?
    By LCDcrazy in forum LCD/Display
    Last Post: 07-26-2001, 02:49 PM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 04:53 AM
