Results 1 to 6 of 6
Thread: Wiring power up a Jetta.
    May 2004
    I'm planning on wiring up a 150W opus PSU somehow. I'm thinking I can run 12 gauge wire to the distribution block on the battery, through the grommet in the firewall, along the door trim on the drivers side, then to the trunk through the seats. I should also try to run a inline fuse rated at 30 or so amps near the distribution block.
    Is this right? Any changes to this plan needed?
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Maybe a thicker gauge wire, i'm not sure...i'd use at least 8
    CarPC install is starting to come along again...
    Maximum Bitrate BoraXP's Avatar
    Jul 2003
    8 or less guage
    otherwise perfect
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Im not sure about the jetta, but for the passat (should be the same) there are two entry points into the cabin. One is through the ECU box on the drivers side which is kind of tricky to do because the ECU box is water tight so you have to drill a hole in the box and make sure its sealed when your done, or drill a hole through the firewall. THe second is on the passenger side, inside the glove box. Remove the glove box and you'll see the hole. There may also be another entry point on the drivers side, following the door, up through the fuse box and up or under some relays.
    too much work for me, so i let best buy do it. g luck
    May 2004
    Thanks for the suggestion of going to 8AWG. Does the amperage on the fuse sound good too? Also what gauge of wire should I use for the ignition? I hear I can go into the back of the fusebox and use the window wiper circuit since it operates only when the ignition is on.
    I found that there are a couple grommets that go through the firewall near the power steering on a MkIV.
    May 2004
    Arkansas
    your comp shouldnt draw more than 5-7 amps MAX, if you're powering a sub or something 20-30 would be fine...otherwise just put a 10 or 5 in there
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Inverter Wiring
    By MoniraInc in forum Power Supplies
    Last Post: 06-25-2004, 09:23 PM
  3. Simple Idea for keeping power to inverter while cranking....
    By syclone477 in forum Power Supplies
    Last Post: 03-23-2004, 10:03 AM
  4. Replies: 1
    Last Post: 03-04-2004, 07:02 AM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
