Results 1 to 10 of 10
Thread: Overloading an opus
    Jun 2004
    Overloading an opus
    Overloading an opus
    What would happen if you overloaded an opus would it just not boot up or would it harm something.
    Jun 2004
    I am talking if you like hooked up to many things is it going to burn out the opus or could it harm some of your computer parts. Or does the opus have something built in so it just wont work if you have to much hooked up to it
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    If you overload an opus as far as can tell it wont have enough power to power some critical componants like hard drive and motherboard and lcd
    Jun 2004
    But its not like you are going to hook up one to many things and just fry something, right?
    You should be able to tell if you are hooking up to much, right?
    May 2003
    Charleston, SC
    From my experience if you overload the opus, then it simply won't power up the PC. I have a problem now where the OPUS is right at it's threshold with one Motherboard hooked up, so when I enable the wireless card, the computer blue screens and shuts down. If I try to start the PC with the wireless card on it gets to where windows initializes the Wireless card and reboots because of too much power. With another Motherboard and everything else the same I can run the wireless card, but as soon as it finds an access point the music gets jittery and the PC eventually freezes, then reboots after a few seconds.
    I may have another issue going on here too, but I know the OPUS is right at it's capacity with my system.
    Car: 1990 White Toyota Celica GT Hatchback, Custom CAI w/ K&N filter, AutoVation Celica Racing Pedals
    PC: Athlon TB 1000, Opus DC-DC Power Supply, 40GB, 8x DVD, 256MB RAM, FM/TV Tuner, 5.1 Audio, 7" Xenarc Touchscreen, GPS w/ CoPilot 2003, 802.11g wireless NIC
    System: Hifonics ZX8000 5ch amp, Sony XS-L101P5 10" Sub, Q-Logic .6 cu ft sealed enclosure
    Coming Soon: Clean install in custom hatch enclosure, USB 2.0 or Firewire hub in front console, Slot DVD in front console, VHF/UHF antenna
    FLAC alti's Avatar
    NY
    Fishy are you powering your xenarc from the opus ? do you have onboard sound and video or cards?
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    It's more of a long-term (meaning several months) issue. The Opus, to my knowledge, does implement some over-current protection so an immediate up-in-smoke scenario shouldn't happen unless there is a short. It also simply won't power up the PC, or the PC will be unstable if you are too far over it's rated output.
    Over time, however, components will degrade at an increased rate due to electrical and heat related stresses present at close-to or over the rated wattage, even though it may run all your hardware.
    KyferEz
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
    May 2003
    Charleston, SC
    Yes, I'm currently running the screen (only draws 7w) from the OPUS and I have an MSI Lite MB, with PCI Wireless 802.11, PCI SB Live!, and AGP 128MB video card. It's weird how I can have everything on and working while sitting in the driveway including browsing the internet, but when I'm driving around it skips and eventually crashes. I think the wireless card is searching for new AP's and dropping others and it's causing the system to draw too much power somehow.
    Anyways, if I were just getting into it I'd go for one of those EPIA boards or whatever the other people are using with the built in processor.
    When I first got the OPUS I had to call them a few times to get everything set up and he was very helpful. We narrowed it down to my processor being too big (i.e. drawing too much power) for the OPUS, so I downgraded from a 1.1 GHz to a 1.0 GHz and it worked. However, I still highly recommend one of those other boards with carPC's...the reg. mini-ATX work, but they draw more power than what's really needed.
    FLAC alti's Avatar
    NY
    that video card probibly is not helping either, high powered video cards draw alot of juice, if you dont need it, go with somehting smaller
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    May 2003
    Charleston, SC
    I wish I would have just gotten a MB with onboard video, it's not like I need anything to run the latest high demand games on, ya know? Anyways, ya live and you learn...and that's what these message boards are all about!
  1. Opus and BMW (e46)
    By captain_jim1 in forum Power Supplies
    Last Post: 01-20-2005, 11:46 PM
  2. Hot Hot OPUS!!
    By god_of_cpu in forum Power Supplies
    Last Post: 06-22-2004, 05:02 PM
  3. Replies: 8
    Last Post: 06-05-2004, 10:13 AM
  4. OPUS and/or Amplifier
    By cpjolicoeur in forum Power Supplies
    Last Post: 04-02-2004, 02:57 PM
  5. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 04:15 AM
