Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Wiring An OPUS to the Battery
    Jul 2004
    Chappaqua, NY
    This might be stupid but i have been searching around the forum for a while and no one has actually given a breakdown of how to actually wire the opus to the batter. Does the wiring have to go straight to the battery or should it go through the fuse box? What gauge wire should I use? Where should i run the wires? what do i need to buy to make sure i can safely wire my opus to my car.
    Constant Bitrate saikano's Avatar
    Jul 2004
    Huntsville AL
    i second this
    don't let a day go by without finding some wonder in it...
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    This is really basic....
    Wire the red wire straight to the battery with an inline fuse (as close to the battery as possible)
    Wire the blue wire to +12 switched (ignition or acc)
    Ground the black wire
    this has been covered
    Jul 2004
    Chappaqua, NY
    ok where can I buy these wires and what gage? the Blue wire that you are talking about......where can I find +12 switched? what is the acc?
    2004 GMC Envoy
    Installed: VIE EPIA M1000, OPUS 90W, 180 Gig HDD, Lilliput 7" Touchscreen, DVD Rom.
    Contemplating: GPS, Mounting ideas, slimline slotload drive.
    Overall Project progress: ()_______|_(90%)>
    Jan 2004
    California
    You will have to dig around with a multimeter. I found 12v+ switched off of the wire harness from my stereo.
    i ran 10awg for the red and black and 14awg for the blue.
    Learn to search before you post dude. This all has been covered...extensivly...ungrateful newbie
    Jul 2004
    Chappaqua, NY
    sorry man ive been searching i was just hoping that someone could maybe explain it a little easier for me. Like what do you mean by 12v+ switched? what does ACC stand for?
    2004 GMC Envoy
    Jul 2004
    Minneapolis
    Okay, just to let you know I'm new to carputers (but learning a lot at this fine site) but I have lots of experience with car audio. Also, I'm in a really good mood because I got a tip today from a guy with a Winnebago so I'll give you some help. The OPUS has three inputs. Battery, Ignition, and Ground. I would recommend using 8AWG wire to connect to the battery and for the ground. If you use 8AWG on power you need to use it on ground as well. A vehicle like an 04 GMC Envoy is gonna be gravy for getting your wire through the firewall because it's just big. Last thing like an Envoy I remember was an 04 Trailblazer and I believe it had a real nice factory grommet with all the wiring coming through. That's a good place to go through with your power wire for the battery. Now, you need to fuse the power wire as close to the battery as possible. As far as the ground is concerned, shorter is better and I recommend buying a wire brush (like $2.99 @ Sears) and hooking it into a drill and get all the paint off of the spot you're going to ground to. Use a star washer and make sure you're not drilling into your gas tank (i.e. look under vehicle and make sure you are not drilling into a GAS TANK). Your ignition wire cannot be found at the radio because those vehicles don't have them @ the radio so you need to go to the ignition harness. Directechs recommends pink as your color and I'm sure that's fine but I would check with a DMM to make sure. Your wire doesn't need to be any thicker than like 16AWG on this. It just trips the relay/transistor/whatever they're using in the OPUS. Hopefully this helps.
    Peace
    Jan 2004
    California
    You can use acc (accessory) Although power is cut of to this line on crank you don't crank your car for 5 seconds...more like 2-3 so it will not initiate a shutdown of your computer.....now if you were getting your positive from the switched 12v (acc) that would be bad news
    8awg is overkill but will definitly get the job done.
    Jul 2004
    Chappaqua, NY
    Where can I buy wire with inline fuses? what fuses do i need?
    2004 GMC Envoy
    Jul 2004
    Minneapolis
    I've always believe too much is never enough. I'm sure you could get away with 10 or 12 AWG if you want to but I will certainly be using 8. Your local Best Buy, CircuitCity, car audio shop, etc. can get you into wire. I think we sell a 10AWG amp kit (17ft 10AWG red, 3ft 10AWG black, 18AWG remote) for like $20 or something like that. That comes with an AGU fuseholder and a 30A fuse I believe.
  1. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  2. Battery dead in car. Opus?
    By Chairboy in forum Power Supplies
    Last Post: 05-13-2004, 12:06 AM
  3. Wiring Opus to battery pics
    By Cyberphox in forum Power Supplies
    Last Post: 04-30-2004, 11:23 AM
  4. opus 150, how long will it run on battery
    By beaverpants in forum Power Supplies
    Last Post: 03-12-2004, 07:14 PM
  5. Wiring Opus directly to battery, please help!
    By touser in forum Power Supplies
    Last Post: 02-08-2004, 12:38 PM
