Results 1 to 8 of 8
Thread: Tank Circuit
    Jul 2004
    Tank Circuit
    I have no electrical building skills. just wiring, etc. I found the parts list for a tank circuit but could not find the parts at the store. Anyone here build tank circuits to sell?
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    dude, its a diode and a battery. at least that will do
    CarPC install is starting to come along again...
    Sep 2003
    Vic. Australia
    What country do you live in, that way someone will probably know somewhere you can order the parts?
    Jul 2004
    I'm in the US. I did the Coyote mod on my lilli, but I can not find the parts for the tank circuit.
    "dude, its a diode and a battery. at least that will do"
    The posts I found searching all assume some knowledge that I do not have. Are these parts directional? Are they hooked in line? Polarity? Should they be parallel to something? What do I hook em into?
    Jul 2004
    Anyone? I know they are out there.
    On a side note; I was thinking of hooking my carputer power to my 1 farad amp cap but it's probably discharge too rapidly.
    Constant Bitrate StationRocket's Avatar
    Sep 2003
    Rochester, NY
    don't sell yourself short. learning all sorts of new stuff is have the fun of having a car pc. If you read the threads about tanks here and check out some of the stuff on http://www.the12volt.com this will all be well within your ability
    PS: the cap's not gonna help you with surviving a crank
    Constant Bitrate bluehcc's Avatar
    Jun 2004
    Queens, NY
    Why won't your pc survive a crank? I had my inverter connect to my 8 guage audio cable and it survive the cranking even after i use computer for 20 min without running the engine. May be its because my battery is only few months old.
    2006 Camry
    Compaq Laptop
    Holux GPS Iguidance 3.0
    7" Xenarc Touch Screen
    Carnetix 1900 Power Supplied, Wireless b/g
    Jul 2004
    Quote Originally Posted by bluehcc
    I have 0 guage running to the trunk. Every wire from my distro block is less than 2' long and I have 0 a gauge ground from my cap and 2 and 4 guage gounds from my various trunk items. I then power a 4 650 wchannel amp, a 1F cap that powers a 800w amp and then my carputer. The amps power 4 mid / tweets and 1 10" Polk. Doesn't sound like too much power but I guess it is...
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 04:43 PM
  2. APC Battery backup used in tank circuit
    By antimatter in forum Power Supplies
    Last Post: 01-12-2004, 03:54 PM
  3. Newbie has a question about Tank Circuit.
    By GScherler in forum Power Supplies
    Last Post: 11-14-2003, 04:15 PM
  4. tank circuit
    By TiTUS in forum General Hardware Discussion
    Last Post: 09-07-2003, 05:05 PM
  5. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 04:00 PM
