Results 1 to 10 of 12
Thread: Another Opus 150 in a Travla C137
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Looks like it fits right in, were there any special mods you had to do for it? ANy hacking?
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Mar 2004
    Vancouver, BC, Canada
    I did the same thing. You have to create your own mount to screw the OPUS to once you take it out of its case, but that is really the only mod.
    Why did you mount your USB/Firewire card in the PCI slot and not in the cutouts above the motherboard connectors?
    Feb 2004
    Florida
    Does the case have fans? How does it deal with heat?
    '02 GTI
    Mar 2004
    The case comes with one fan. That goes beside the PSU. It appears as though srcstc removed his though.
    Dec 2003
    New Jersey
    Quote Originally Posted by archimense
    Yeah after I mounted the PSU I realized I forgot the fan. I'm either gonna put the fan elsewhere or move the PSU over a bit.
    Dec 2003
    New Jersey
    I'm not planning on putting in a PCI card for a while and there's just more room above the HD for all the cables.
    Variable Bitrate craigyb's Avatar
    Sep 2003
    UK, Sale, Cheshire
    I added a fan to the other end of my C137 to draw air through the case, I used a 40mm CPU slim fan that I had around. Now I get a through air flow over the OPUS whch is mounted in exactly the same place as this one....
    You can just see the fan to the left of the DVD drive....
    Craig
    Audi S8 supercar
    Modded Xbox 400GB HD
    Rear 7" screen & navplus
    Toyota Hiace Van
    Shuttle PIII 866 256Mb 10GB OPUS powered
    MediaCar & Mappoint 2004
    Custom fit 7" TFT VGA TSK
    Jul 2004
    so you flushed the 90W power supply that came with the case right? It's sad we can,t buy a case alone without the Power Supply.
    Where did you buy yours, on travla's website, the only e-sellers that has teh case sells them with a mobo mandatory... and only one has the M10000 but it's 354$ for case + mobo + PCI riser (that should be included with the case)
    Etienne
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    If by 'another' case you were talking about mine (havent seen many people putting 150w opuses into C137 mod), then the photo is above... The 150W opus will fit in there even inside the stock case. I used velcro to adhere it into the case.
    Two small modifications were done to facilitate this. First, the mounting bracket for the CF reader was dremmeled off to make room for a longer PCI card. If you're not using PCI cards, or if your cards are very short it will fit without modificaiton. Second, I moved the molex connector on the Opus 150W to the other corner. There are two places it can come out of the PSU chassis, so this move was fairly obviously necessary. You can see the fitment in the photo. The fan grille lines up pretty well with the holes in the C137 case, and cooling hasn't been a problem even with outside temps up to 110 degF
    On the C137, a one slot riser card and extension needed to work with Mini ITX boards does come standard. The case comes standard with a 90W psu (unregulated). If you want to use 2 pci cards, you need to get a 2 slot riser card and another pci extension thing. (you dont need a pci extension if you are using a flexatx board instead though). The 90W PSU is a very good PSU, and would be good to sell to someone who is willing to build a regulator, tank circuit, and shutdown controller. I did not want to take the time, so that is why I got the OPUS!
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
  1. Opus 150 and Athlon XP?
    By philstuf in forum Power Supplies
    Last Post: 04-18-2005, 08:05 AM
  2. Travla C137 & OPUS & ITX P4
    By craigyb in forum General Hardware Discussion
    Last Post: 11-13-2004, 09:51 AM
  3. OPUS in a C137 case
    By craigyb in forum Power Supplies
    Last Post: 06-27-2004, 01:42 PM
  4. OPUS 150 watt now in stock in the official mp3car store!
    By Zip-Lock in forum Power Supplies
    Last Post: 06-24-2004, 06:56 AM
  5. OPUS 150 watt, USB stays powered???
    By GScherler in forum Power Supplies
    Last Post: 12-19-2003, 02:44 PM
