Results 1 to 3 of 3
Thread: Switched 12v
    Newbie badass101's Avatar
    Jul 2004
    Berkshire, UK
    Switched 12v
    Does the Opus/ITPS/Others draw a large current from the 12v switched line?
    My car uses intelligent switching via the CAN bus, so a switched 12v line isn't available from the stereo. I've tapped into a line which is switched 12v and I use that to turn on my amp/car kit (they just use the 12v as a 'sense' voltage).
    Problem is, I don't know how much current this line can handle - not a lot I wouldn't think.
    Would an Opus be suitable, or does it actually use the 12v switched for power?
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    it dosent use 12v switched for power, in fact it draws hardly any current from the ignition line, but if u have multiple devices running like amps as well it might be a good idea to use a relay
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    The Opus/Carnetix etc uses probably <20ma on the switched 12V line, all they do is sense for voltage on that line, they don't use it for power, that is what the nice thick cable that you will install directly to your battery (with a fuse near the battery!) will do
    Co-Developer of A.I.M.E.E
  1. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 01:47 AM
  2. switched +12V for LCD, amp & opus?
    By Saurk in forum Power Supplies
    Last Post: 07-22-2004, 05:10 PM
  3. Possible Solution for Dual Sproggy 12V @ 10A
    By mp3z24 in forum Power Supplies
    Last Post: 07-10-2003, 01:33 PM
  4. PSU 12V issue
    By Shades in forum Power Supplies
    Last Post: 05-23-2002, 03:59 AM
  5. Finally, 12v @ 5amps !
    Last Post: 08-19-2001, 06:47 AM
