Results 1 to 6 of 6
Thread: Grounding Amp and Pc
    Newbie Ripsurf's Avatar
    Jun 2004
    Southampton, UK
    Hi All
    Just a quick question...
    I was going to use 8 AWG wire from the amp to the chassie of the car and 12 AWG the the OPUS to the car chassie. What i want to know can i use a distribution box, so i would have 8 AWG from the Amp to the distribution box and then 8 AWG from the distribution box to the car chassie then 12 AWG from the OPUS to the distribution box??
    Cheers
    Mar 2004
    Montreal, Qc.
    My understanding is each device should be grounded individualy.
    The ground wire should be very short and thicker then your main power wire.
    VWMAN
    "Live Long And Prosper"
    car: VW Cabriolet '90
    puter: M10000(toasted), Lilliput, CarNetix
    status: In Progress
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    You will be fine using the distribution block.
    ATVMS.com
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    yeh, that will be fine, grounding induvidually is wrong, common ground points are going to reduce interference.
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Quote Originally Posted by no1knows
    Common grounds are good for cetain electronics especially ones that are pulling or producing the same amounts of power. A device like an fm modulater will pull tons of interference if groud with an amp. Same with inverters and the like. My suggestion is try out the opus ground to distro block and if you are picking up interference through the speakers, give it it's own ground.
    Jun 2004
    Southampton, UK
    Ok, Thanks for the information..
    I can now start to wire the carputer in
  1. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 02:41 AM
  2. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 05:27 PM
  3. PC Power Supply and Car Amp
    By GezusK in forum Car Audio
    Last Post: 05-10-2006, 12:31 AM
  4. Any VW MKIV owners run their PC direct to the Monsoon amp?
    By Semler in forum General Hardware Discussion
    Last Post: 04-02-2004, 03:04 PM
  5. PC -> Amp and HU - Amp question
    By Nokia6600 in forum Newbie
    Last Post: 03-24-2004, 04:42 AM
