Results 1 to 2 of 2
Thread: Solution for Power for Car PCs
    Low Bitrate riuster's Avatar
    Jul 2004
    NYC
    Problem:
    Laptop or computer connected via inverter from the car battery, everytime you turn off the ignition, you have to turn the invertor off, although some will not drain the battery completely and leave enough for start up of ignition. Still, turning off the computer on and off for daily errands can be a Pain in the neck.
    Solution:
    I decided to buy a 12volt Battery from www.batteryweb.com with 55amps of drainage power. Its a big bulky HEAVY thing, recharged daily with my battery charger. The laptop and creative soundblaster NX2 is linked to this via cig lighter adapter. It runs without being shutoff through out the complete day, without a needed recharge on the battery, it lasts about 16 hours straight or even longer, since the laptop and creative NX2 does not take alot of amps.
    Does it work:
    Yes it does, so when ever I run errands, I leave the PC on, without shutting it off, its cooled with laptop fans in my backseat, without any heat issues. I leave the car, come back and the laptop is still running..so I dont have to shut it off and turn it back on all the time..HOW CONVENIENT.
    my 2 cents
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    Now get rid of the invertor for a more efficient power supply so the battery will need charged less. Then get a battery isolator and wire it up so you can charge both batteries from the car. Dual battery setups are used by a lot of people, I have a second battery but no isolator at the moment.
  1. Replies: 1
    Last Post: 03-04-2004, 07:02 AM
  2. Data logging solution for non OBD2 cars...
    By doig in forum General Hardware Discussion
    Last Post: 11-06-2003, 11:29 AM
  3. Neat mini PCs on E-Bay
    By mtmsol in forum Classified Archive
    Last Post: 10-07-2002, 02:02 PM
  4. Possible solution to the inverter dilemma...
    By gregulator in forum Power Supplies
    Last Post: 08-07-2001, 10:38 AM
