state what u actually want to achieve............... :S
i have a non epia mobo. it needs 12v input, it hasn't an ATX connector, but just the 12v input (it has a 12v to 5v to 3,3v converter builted inside).
the problem are:
1) it needs 4,5A (DVD+HD+Keyb+Mouse), it needs more if i use other peripherals like FD or USB. on user's manual reccommend 7~10A
but naturally for now i don't need other peripherals so 4,5A would be fine, having an ITPS 8-9A would be great.
2) i tried ITPS theese are the results:
engine on: 14,4V --> ITPS 11,85V --> all ok
engine on, light on, 2 phone, car stereo: 13,1V --> ITPS 11,75V --> all ok
engine on, Air Conditioned on: 12,8V --> carputer off
engine off: 12,01V --> carputer off
what i have to do?
It sounds like the ITPS is barbecued. It refuses to operate at 12.8v or less
Carputer currently 'ghettoed' into car!!!
EPIA MII-12000
Ampie Case with rigged extra USB
Hitachi 60GB
Holux GPS mouse with iGuidance 2.0
Lilliput 7" touchscreen
Netgear WG121 USB WiFi
Carnetix P1260
The ITPS needs at least 13.3V in to provide 12V out. This means you need the engine running, and by the looks of it, no peripherals in the car on, which is obviously not what you want.
Take a look at the Carnetix CNX-P1260, it does what the ITPS is currently doing, only better (ie it will actually work in all those situations you listed above)
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Denun you basiclly require a 12v @ 10amps with input 7~18 .. This can be done
If you have any electronic knowledge Email me and i can help you.
Mastero
Where are you getting your power to the itps from? If you are feeding off the accessories lines then perhaps that might be the problem. You might want to try running it straight from the battery with about a 10 or 8 gauge. It may just work...or it may not. Just a thought.
PS. Hey mastero, how do you like india? Where abouts are you?
Originally Posted by NovaKane
India is a nice place has its pros and consi am in Mumbai the heart of India
Mastero
