Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Power question
  1. #11
    They make 5V 5A regulators (I think Linear might make one).
    As mentioned don't try to parallel them.
    Also note, if your hub draws 2A you will be dropping ~9V across your regulator generating 18W of heat. You will definitely need a heat sink for that.
    Without knowing the USB spec off the top of my head, and without knowing how many ports you have, I am going to guess USB provides for 500ma per port (and a guess is you have 4 ports) for 2A, and then 100ma to run the logic in the hub.
    It is entirely possible you will need a very miniscule heat sink for this, just be aware of it.
    For the capacitors put a .01uF and a 10uF on both input and output (maybe a bit bigger one on the output) and you should be fine.
  2. #12
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    The caps I would got with a .01uF and a 1000uF rated AT LEAST 24V
    you could rip apart the wall adapter and see what kind of goodies it has.
  3. #13
    Low Bitrate cyber's Avatar
    Jun 2004
    Frozen Tundra
    Ok, I went by rat shack and picked up a .01uF and 1000uF capacitors as well as a small square of bread board, small project box, and heat sink and thermal paste. I looked at voltage regulators and all they had were 5v at 1amp so I found a 5v 3amp on the internet and ordered it. One more question, which capacitor goes where? 1000uF on the input side or the output?
  4. #14
    FLAC ppgt94's Avatar
    May 2001
    Hey Cyber let me know how this works out. I have the same issue.
  1. Power Supply/Electronics Question
    By archimense in forum Power Supplies
    Last Post: 06-10-2004, 02:43 PM
  2. Power on/off question
    By arkadiyp in forum Newbie
    Last Post: 03-25-2004, 03:53 PM
  3. Power consumption question
    By S4Per in forum Power Supplies
    Last Post: 02-16-2004, 06:08 PM
  4. Question about power and inverters and all that
    By SBmp3 in forum General Hardware Discussion
    Last Post: 05-01-2003, 12:35 AM
  5. Power Supply & TFT LCD question
    By VegaBOND in forum General Hardware Discussion
    Last Post: 03-23-2000, 07:07 PM
