Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Opus won't start up PC
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    I have a 150W opus powering a micro-ATX mobo, 3.5" HDD & DVD-ROM.
    When plugged in (wired correctly) the opus leds blink with the 0.1s on 2.5s off indicating its OK & in standby. I have the green/white wires connected from the starup controller to the power pins on the mobo.
    When I start the vehicle the PC doesn't start. If I short the pins myself the PC fires up & runs fine. I've tried reversing the pin connector in case it is polarity, but no change.
    Any ideas?
    Feb 2004
    NYC
    have you checked to see if that green/white wire is defective?
    What I did on mines is plug the green/white wire onto the board and using a linked copper wire and short it on the other end.
    From the looks of thing, your motherboard is fine and your opus seems to have power.
    pip
    pip is offline
    Mar 2004
    Parker, CO
    I shorted the pins by connecting the opus end of the green/white wires using a staple. I think the wire is OK.
    Feb 2004
    NYC
    is your yellow wire connected correctly?
    Aug 2004
    i ahve the exact same problem you are getting. same mobo and the same opus power supply and i can not get it to turn on automatically. i too have to use a push button switch to turn on the motherboard.
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Quote Originally Posted by nl4jy
    I'm pretty sure it is, but that would explain it too. I'll check with my voltmeter when I get home.
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Quote Originally Posted by go0gies
    Did you buy your Opus recently? If the suggestion above doesn't pan out I suspect there may be a bad batch of startup controllers.
    Edit: Hmmm, same motherboard huh? The mobo requires a momentary connection of the power pins to start up. Does the opus put a constant or momentary signal to these pins?
    If it is constant, how do I make it momentary so it will start up the mobo correctly?
    pip
    pip is offline
    Mar 2004
    Parker, CO
    That seems to be half the problem. I'd blown the accessory fuse, replaced it & yellow wire now has power whe the ignition is on.
    However, now I have two flashing blips from the leds. Time to play with that wire again.......otherwise I have a duff DC-DC supply.
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by pip
    Two lights is a problem with the green-white cable right? Make sure you get the right polarity.
    Installed.
    -GPSSecure- - GPS Tracking
    Maximum Bitrate 00CericaRuss's Avatar
    Jul 2002
    San Rafael, CA, USA
    yep.. and make sure nothing's grounding out as well
    Car: 2000 Toyota Celica GT-S
    Mods: Yep
    Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
  1. A Bodgy Car PC.
    By Bodgy in forum Show off your project
    Last Post: 02-05-2007, 11:58 PM
  2. Opus and BMW (e46)
    By captain_jim1 in forum Power Supplies
    Last Post: 01-21-2005, 12:46 AM
  3. Replies: 8
    Last Post: 06-05-2004, 11:13 AM
  4. opus wont start, ign wire...?
    By Richie in forum Power Supplies
    Last Post: 03-19-2004, 11:25 AM
  5. FS: Casio EM500 Pocket PC / 800mhz Desktop PC / Misc
    By gguy in forum Classified Archive
    Last Post: 10-07-2001, 09:00 PM
