Results 1 to 4 of 4
Thread: Can't get my OPUS to power up PC
    Aug 2004
    SE England
    Hi and thanks in advance for your help
    I've just changed from an inverter to an opus 150w (shuttle version) and have encountered a bit of a problem.
    My 12v+ is an 8 guage direct feed from the battery with an inline fuse 4" from the battery terminal, my ground is also 8 guage and runs to a big bolt under my rear seat (this is where my inverter used to ground, and my amps too), my ACC line is from the original feed for the headunit i no longer need.
    In ignition off I get a solid reading from the 12v+ using my ground wire to test, and 0 from the acc. In ignition on i get a solid reading from both.
    I used to have a power button in the dash which ran from the MoBo directly (in this shuttle mobo there is no seperate block for power, reset, and leds, instead there is a single block with a multi connector) i worked out which 2 leads started the power snipped them and wired to the front, where they worked fine for months. I have attached the green/white wire to these snipped cables.
    When I start the car the PC powers up for a moment then looses power, off for 5 or seconds and then blips on again, etc...etc...
    It starts just long enough to spin the fans on the case and video card and then off
    Any help would be well appriciated
    <small>Opus 150w Shuttle dc-dc
    shuttle xpc
    athlon 1400
    256Mb pc2100 DDR
    80Gb HDD
    Sony DVD/CDR
    GeForce MX440</small>
    Maximum Bitrate 00CericaRuss's Avatar
    Jul 2002
    San Rafael, CA, USA
    try flipping the wires that go from the opus to the power switch header, and check for anything grounding out
    Car: 2000 Toyota Celica GT-S
    Mods: Yep
    Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
    Feb 2004
    NYC
    sounds like your powerbutton is set on push on. PCs will automatically turn themselves off when the power button is pressed for 4-5 seconds. Check to make sure the wire is not constantly in contact
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    Hi just had this problem! It turned out that the Push Button I purchased was the wrong type. Instead of push for on it was push for off. As stated above, holding the push button (power button) for 4 seconds powers the PC off. To test this theory, hold the push button down, start the car, keep holding the button down. If it continues to boot up, you have found your problem. You will need a different type of push button. (I'm temporarily using one from an old computer case).
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
  1. Opus doesn't start/stop PC
    By meetmandeep in forum Power Supplies
    Last Post: 06-20-2004, 03:01 AM
  2. 150w Opus Power Supply for sale on eBay! - UK
    By alex1976 in forum Classified Archive
    Last Post: 06-01-2004, 02:33 AM
  3. Replies: 1
    Last Post: 05-01-2004, 06:17 PM
  4. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
  5. Mp3Car.com Store carrying OPUS Power Supplies
    By Zip-Lock in forum Classified Archive
    Last Post: 02-24-2004, 11:39 AM
