Results 1 to 3 of 3
Thread: Vector VEC018 pocket power
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    http://www.vectormfg.com/site2/vecto...products_id=72
    could this be used as a tank somehow? run it in parallel right before a power inverter to survive crank? i saw it today at pepboys. this is all the site says:
    FEATURES:
    * Portable power to run/charge cell phones, camcorders, TVs, worklights, radis, laptops, vacuums, inflators and more
    * Easy to use, simply plug 12 volt DC device into built-in power socket
    * Cordless and rechargeable from home or vehicle
    * Compact & Lightweight (4 lbs)
    * Rapid charge your cell phone in less than 30 minutes. Provides three hours or more of extended talk time
    *Maintains vehicle's electric memory setting if battery is disconnected for service/repair
    INCLUDES:
    *Built in 12 volt DC accessory receptacle
    *110 volt AC wall charger
    *Sealed, 6 amp hour, 12 volt non-spillable lead acid battery pack
    *12 volt DC charge for use with 12 volt accessory outlet
    *Durable nylon case with adjustable shoulder strap and belt holster
    for $20 it might be perfect to smooth out the voltage during crank.
    rebuilding carpc... kinda..
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    buy it, and put a mutil-meter on it during cranking...
    if it doesn't do what you want it to..bring it back...
    OR just buy and opus!
    BossTone74
    Nov 2003
    CT
    this is what im thinking of...but somehow i think there should be some sort of diode in there or resistor or something...
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  3. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
  4. Brief power loss between ACC and start
    By Destin in forum General Hardware Discussion
    Last Post: 01-26-2001, 11:12 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
