My suggestion is for the hardware you own, get an ammeter and measure the actual current draw and using P = V * A (power = voltage[volts] times current [amps] assuming DC current). Do this carefully and by placing the ammeter in series with the power leads. If you don't feel comfortable doing this or don't understand how and don't care to try, look up all the data sheets for the items you wish to use and then add 10% or 25% to be safe of the power requirements. Specifically look through all the manuals or specification for each thing you want to power and find the maximum power usage for each and then add those up. This is really all very rough estimation and learning how to measure the power draw can be very useful. Good luck!
LinkBack URL
About LinkBacks
