niiiiiiiiice
My carputer is a Shuttle with P4 2.8ghz, 512mb ram, onboard ATI Raddon 9100, SoundBlaster Audigy 2 ZX, floppy drive, and 80gb 2.5" HDD.
The PSU to the carputer will be a 150watt OPUS hardwired to the vehicle's battery.
Other components include 2 USB hubs with their own power supply and with USB touch screen, USB wireless keyboard and mouse, and a USB external DVD drive connected to them. The screen will be a xenarc 10.4" lcd.
I already have an inverter in my vehicle to supply power to a VCR and PS2. So could I just get power from the inverter for the 2 USB hub ? For the components that attaches to the USB hub, do they get power from the USB hub ?
Also for the xenarc 10.4" lcd, it requires a 12v power. Could I just hardwire it to a 12v switch from my vehicle ?
Bascically if my system is wired this way, will there be any problem ?
Thanks,
Clement
but the outside looks weird - what kind of car [scratch that] vehicle is that?
nine.
It's a Honda Odyssey. It has full molded bodykit from Japan , air bag suspension, and 20" wheels.
more info here:
http://www.hondashowoff.com/profile.php?id=3766
I just realized that I can use the 5v out from OPUS to power my USB hub, and other components that plugs into the USB hub will get power from the hub. Correct ?
Yes, that's correct. The only thing you need to worry about is the capacity of the opus... But I think it will be sufficient (the powered hubs only draw as much current as the devices connected to them).
For the screen, I would recommend some kind of regulator, as the car delivers typically something between 11,9 and 16v (not even talking about cranking)...
Nice 'car'![]()
So bascailly everything is powered by a 150watt OPUS. 12v to the Shuttle PC and 5V to hub and components. Then a 12v regulator for the screens.
I really have no idea if I will over load the OPUS. Some say it will work and some say it won't. If in case the OPUS is not enough, what are my options ? Another OPUS ?
After reading the forum, it seems like the ITPS does not work well as a regulator. Another choice would be the Carnetix CNX-P1260. Any other better alternatives or will the carnetix be fine ?
hey, saw you at DTP this year
looking really good!
-K
