If you know the pinout of the harddrive's connector (and it sounds like you do) then you can wire a molex for power. I am confused about your description of the connector. Does this connector run from a wallwart to the harddrive? If so, you can run the yellow molex wire to +12v, run the red to +5v, and run the common (ground) leads to the black wires.
LinkBack URL
About LinkBacks
