Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Does the Opus works with the Insight P4?
    Feb 2004
    NYC
    I just purchase the Insight P4 mini-itx motherboard... The M10k is just not fast enough to do what I want it to do. But I've been hearing imcompatibility with micro-atx board with the Opus.
    Anyone knows if there's a problem with Opus and Insight P4? Or will I be the guniea pig? (oink, oink)
    I can't wait for that thing to arrive. I already purchase a P4 2.8C chip and a 1U heatsink/fan. This unit will be place in the same exact location as my current board. I'm just hoping it would fit with that Opus in there.
    So, a second question arose...Can I take the Opus board out of the tin shell? Will there be any problem as I will not use the fan if I do that.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    There is a known problen with a specific model micro-ATX (mine )
    You can take it out of the shell, I have. Not having the fan could allow more heat to build up, but I just removed the fan from the casing and velcrod it in place to the side of the supply.
    Jul 2004
    Atlanta, GA
    I don't think guinea pigs go "oink oink"...
    Sorry, I didn't have anything constructive to say, but... yeah...
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    Quote Originally Posted by nl4jy
    You'll be fine. I'm using OPUS 150W with the Insight M/B and a Celeron 2.4GHz and it works just fine.
    Feb 2004
    NYC
    Quote Originally Posted by Seth
    Thanks...That's exactly what I wanted to hear.
    Only now, I need to figure out if the 150 is good enough for me....
    Insight P4
    P4 2.8C
    Full Size Slot Loaded DVD Drive
    Full Size HD
    misc USB devices.
    (weeeee-eeee, weeeee-eeee) ? I remembered my guniea pig did that noise.
    >_< gotta save money to repair my bumper. and to add projection headlights...
    Don't want to spend anymore on this thing till after the repairs and mods.
    Jun 2004
    Athens Greece
    Hmmm...fullsize components are a problem. Too much 12V drain. I used a slot DVD and a 2.5" hdd (both use the 5V line). I think you should e-mail Kris at OPUS and ask him. At least if he says it can cope with your hardware and turns out it can't you could claim your money back!
    Feb 2004
    NYC
    moving a little off topic here...you guys that have the Insight P4. Does it support the native resolutions of our Xenarc/Lilliput or not?
    Feb 2004
    NYC
    Okay, back on topic. I just tried to install the board and the opus together, turn on the engine and it doesn't turn on.
    I tried the board @ home, and it works out great.
    You said you didn't have any problem with it, how did you make it work?
    Feb 2004
    NYC
    Update: I'm an idiot!!!!
    Turns out, I had the jumper/power switch on backward. After reversing the polarity, I am able to turn on the PC with the iginition.
    Now..... Problem is shutdown. It seems to shutdown the PC, yet the PSU still runs. Maybe it's the way I setup standby/hibernation.
    Here it goes:
    Motherboard BIOS: set to S1
    Powerbutton is set to instant-off
    Windows set to Standby when button is pressed.
    Hopefully, it would not drain my battery before I get off work. I was working on it this morning before work.
    Just switch the jumper during lunch. Tried out software, GPS, etc..
    Turn of engine and ready to leave... Usually it'll take about 5 seconds to shutdown to standby, but I was waiting for minutes, and yet it didn't shutdown.
    Turning the engine back on, Xenarc only display a blank screen, but I can clearly hear the PSU fan blowing.
    Any Ideas? Gonna work with it after work.
    Feb 2004
    NYC
    Okay, I'm able to get it to Hibernation mode. But that takes forever to load up (cause of post bios screen) Somehow I can't set it to standby mode.
    What exactly am I supposed to change (beside power settings in windows) In windows, I set it so the power button is set to standby. But everytime I turn on the PC, it's as if the PC is turned off. Doing the loading Windows and stuff.
    Any help here?
  1. Travla C137 & OPUS & ITX P4
    By craigyb in forum General Hardware Discussion
    Last Post: 11-13-2004, 10:51 AM
  2. Will OPUS work with regular P4 Motherboard
    By badandy4you in forum Power Supplies
    Last Post: 06-22-2004, 01:55 AM
  3. Dell GX260 SFF P4....will opus 150w work
    By Oracle in forum Power Supplies
    Last Post: 06-04-2004, 10:57 PM
  4. P4 2.6ghz 800mhz fsb Shuttle XPC + Opus 150W DC-DC
    By robutek in forum Power Supplies
    Last Post: 01-05-2004, 02:10 PM
  5. P4 power alternatives?
    By tejesh83 in forum Power Supplies
    Last Post: 06-24-2003, 11:47 AM
