Results 1 to 5 of 5
Thread: Removing Opus 150 Casing
    Jun 2004
    I would like to remove my opus 150 from its case so I can mount it inside my carputer case. Im not sure how I would go about attaching the board to the inside of custom case (made of metal). Does it need to be touching the metal case, or can I just put it on some plastic risers? Thanks for any help.
    FLAC ppgt94's Avatar
    May 2001
    USA
    I'm pretty certain as long as it's grounded (through the ground wire) putting in a plastic riser is fine.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    If the underside of the board touches the case be prepared for fireworks etc. I used nylon risers to space the supply from the case and used rubber washers to protect from vibration too.
    Low Bitrate Speg's Avatar
    Mar 2004
    What about Plexi-glass case? Would static be a problem?
    Mar 2005
    I want to get at the jumpers in my opus 150, but after taking out all the screws it still feels like I'm going to break it when I try to take the cover off.
    Is there a trick to taking this thing apart?
  1. Opus 150 and Athlon XP?
    By philstuf in forum Power Supplies
    Last Post: 04-18-2005, 09:05 AM
  2. OPUS 150 low battery shut down
    By archimense in forum Power Supplies
    Last Post: 09-08-2004, 04:28 PM
  3. OPUS 150 watt now in stock in the official mp3car store!
    By Zip-Lock in forum Power Supplies
    Last Post: 06-24-2004, 07:56 AM
  4. Will it work? Your best guess. Opus 150
    By the_dude in forum Power Supplies
    Last Post: 05-05-2004, 09:09 PM
  5. opus 150 or opus 90, you decide, i buy
    By faiz_23 in forum Power Supplies
    Last Post: 04-30-2004, 12:43 AM
