Results 1 to 8 of 8
Thread: Powering FM Modulator
    May 2004
    Hi,
    My carputer is almost done but i'm having one last problem. I just went out and got an FM Modulator and it comes with the options of using two AAA batteries to power it or you can plug it into a 12V cigarette lighter. Using AAA batteries would get pricey over time so I was wondering if there was a way to hook it up to the computer's PS some how?
    Thanks!
    FLAC migel628's Avatar
    Mar 2004
    New Windsor, NY
    I would imagine if it takes 12v that you could splice into the 12v off of the PSU. Better yet, get a Y-splitter & lob off one of the ends...That way there is in perm. damage to the PSU...Just an idea, I could be wrong though
    I would also guess that somewhere in the 12v source there is some kind of resistor or step down network, b/c I beleive that 2 AAA only produce 3V (1.5V each).
    Please correct me if I am wrong...I hate giving misinformation...
    "I'm a dick!"
    "I must seek knowledge and it's bastard son truth" - The State
    May 2004
    I have no issues with splicing because it's an older computer and i got it for $40 . But which wires is the 12V? is it the connector that is plugged into hdds, cdroms, etc to power them? If so there are 4 wires which ones would be neg and pos?
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Use the end of the cigarette lighter (12v) and connect the positive part (the tip) to the yellow and the black wire closest to the yellow wire to the negative (the other bit on the side) indicated in the diagram. It would be preferable to splice/solder the wires into place.
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    May 2004
    Sweet Thanks!!!
    May 2004
    Uh o,
    So i got it to work but now it doesn't auto turn on when it receives power. I'm using the iRock 400FM - http://www.myirock.com. Any ideas?
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    does it have a switch on it?
    you may have to remove it and hook some wire together from the switch
    BossTone74
    It depends on what type of switch, i'm guessing it is a standard SPST switch. If this is the case you can replace the the switch with a cheap relay, and wire the relay onto your computers 12v line so when power is applied to the computer, the relay closes and the fm transmitter powers on.
    Connect the 12v and The Gnd Wires to the same place that you conenct your fm modulator to the computer's power.
    There are also other useful schematics in the Schematics/Pin Outs/Diagrams thread, especially the one by stimps which shows you various ways of emulating switches.
    Fox Mulder
    2004 Toyota MR2
  1. FM Transmitter vs. FM Modulator
    By Uzi4U in forum Newbie
    Last Post: 02-18-2005, 10:20 PM
  2. FM Modulator Help
    By captain_jim1 in forum General Hardware Discussion
    Last Post: 04-07-2004, 04:12 PM
  3. Integrate mp3 player w/ Alpine FM modulator ?
    By L0C0 in forum General Hardware Discussion
    Last Post: 03-04-2004, 01:45 AM
  4. FM Transmitter / FM Modulator
    By owenjh in forum General Hardware Discussion
    Last Post: 12-30-2003, 07:29 PM
  5. Which one is better? FM Transmiter or FM Modulator
    By helloman in forum General Hardware Discussion
    Last Post: 03-12-2001, 10:15 AM
