Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: Looking for 2nd opinion: +12v & +5v only, no need for AT/ATX or neg rails
    Constant Bitrate Gibson99's Avatar
    Aug 2004
    Houston, TX, USA
    well i tried to search, but terms like that are being blocked as "common used words" or it actually interprets the NOT as an operand, not a regular word.
    anyway here's what i've got: a SBC mainboard that, instead of an AT or ATX power connector, has a connector identical to the one you'd see on the back of a cdrom or hdd. yup - it actually only needs +5v to run, but you get better quality sound if you give it +12v as well. so at home i'm testing it with an old 45W AT power supply, with the AT leads just dangling. for the car i want to go the direct DC-DC route for space and efficiency, but i'm not sure what's out there, and would like to build my own p/s instead of shucking out $150+ for a p/s that (imho) just has more parts to break and aren't needed.
    I was thinking of getting the ITPS and feeding my +12v rail for my HD, CDROM and mobo directly from the ITPS, and then making some sort of regulator or transformer to drop the regulated +12v down to regulated +5v for the mobo and drives.
    so my question is, do you think i can do it this way? i can switch it all externally with relays and switches, and can do a fake UPS no sweat (got 4 serial ports to play with!) what would you recommend as a way to drop the 12 down to 5 in a way that won't overload anything?
    Previous: CamryAmp 1.0 - 95 Camry SE V6 Coupe (sold)
    Current: CamryAmp 2.0 - 98 Camry CE V6 5spd (still bench-testing)
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    12V: TI PT5071
    5V: TI PT6653D
    Or
    Just build the +12 and +5v portions of Mastero's Sproggy (MK3.5, MK4, or MK4.5).
    It doesn't get much easier.
    FLAC Mastero's Avatar
    Aug 2001
    India
    Email me and i can design you what you require ... it shall be small and you shall have a full kit to build your own ....
    Mastero
    Mar 2004
    Redondo Beach, CA
    Having Mastero design a kit for you is quite possibly an even easier solution.
    I stand corrected.
    Aug 2004
    Houston, TX, USA
    cool, thanks mastero. i'll email you in a little bit once i come up with my requirements. it probably wouldn't be hard to put the relays onboard, which would not only make the install smaller (very important in a mazda mx5!), it would be simpler to install, too.
    after reading more and more on the forums, it sounds like the istp (or whatever) will not work for me, since most people say it doesn't survive engine cranking, and doesn't run (most of the time) with the engine off. but the sproggy DOES. and that's what i want. thanks again mastero.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Look on my site (Hardware page). I have exactly the same situation, and built a 5v/12v power supply specifically for the em586. Based around a PT5071 and a PT6625, the entire power supply sits over the motherboard keeping your system footprint down.
    These regulators even have a switch-on pin that removes the need for relays on the input.
    Aug 2004
    Houston, TX, USA
    Quote Originally Posted by Rob Withey
    so you have the voltage from your car going straight to your powersupply with no external regulation? very interesting indeed. however, i will be hanging a lot more hardware off mine than what you're running - a big 3.5" hdd, a cdrom, pcmcia wifi, usb touchscreen, and eventually GPS (likely also usb). plus my cpu, though an amd, is running at 300 mhz - more juice.
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by Gibson99
    Correct.
    The power supply on my site should be good for 5A at 5V and 1.5A at 12V. You may need some heatsinks/forced airflow. I have a heatsink on and a fan sitting right over the 5V regulator.
    Aug 2004
    Houston, TX, USA
    well after doing a little more searching and reading, i think the carnetix is what i need... except i will need to mod the cnx to also have a 5v rail. i think i can just build the 5v side of rob's mk2 p/s, which would be fed from the 12v output of the cnx. and conveniently, the cnx has an unused wire on its 6 pin output - the white one. i can probably put the +5v out into this wire. i wonder if it'll all fit inside the cnx casing... <evil grin>
    Mar 2004
    Redondo Beach, CA
    The carnetix is a good choice for a high power 12V regulator.
    Rob's 5V supply (PT66xx based) can be fed directly from your battery...just like the carnetix. There is no advantage in powering it from the Carnetix. In fact, you'd just be wasting a good chunk of your Carnetix output in doing so. Rob's supply has a turn-on wire that can be fed from the carnetix so that they come on/off together.
  1. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  2. Replies: 15
    Last Post: 08-07-2004, 10:09 PM
  3. Replies: 5
    Last Post: 08-20-2002, 09:29 PM
  4. replaced MAX chips and still 12v on 5v rail
    By surfer6262 in forum Power Supplies
    Last Post: 07-15-2002, 12:51 PM
  5. Why does my sproggy supply 12v on all rails?
    Last Post: 06-20-2002, 03:51 AM
