Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: opus 90w Vs. 150w
  1. #11
    Aug 1999
    Washington D.C.
    Quote Originally Posted by Udonboy
    About how many things can you connect up using a 90W opus? Right now I'm in the planning stages and I don't know if I should get a 90W or a 150W opus.
    Here's what I'm thinking of running:
    VIA EPIA M10000
    Segate 40GB 5400 rpm
    512MB PC2100
    Toshiba CD/DVD-ROM
    Lillput 7" TFT VGA
    AutoEnginuity Scantool
    some GPS unit
    and possibly a FM/TV Tuner.
    I'll prolly hook up a USB hub up to this too. It sounds like alot of stuff to me. Will a 90W do it?
    The OPUS 90 watt should work with this setup.
  2. #12
    Low Bitrate Udonboy's Avatar
    Aug 2004
    Anaheim, CA
    Cool, thanks alot!
  3. #13
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    So, if the 90W Opus cuts all power on shutdown, does that mean that you can't use Standby?
    If so, then you are missing out on the best feature of the Opus.
    <-- Only has a 150
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  4. #14
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    theres a jumper on the opus that can disable/enable power after shutdown
    Signature: [==||========] 20% complete
  5. #15
    Super Moderator xBrady's Avatar
    USA
    I would get the 150W. Sure you can save a few bucks with the 90W but it is sure going to suck if you ever have to upgrade. I wouldn't worry about it draining your battery. Mine goes into standby and I have left it for plenty of time without it draining the battery. Frankly I don't think I have even heard of anyone's battery dying from using a 150W.
    Installed.
    -GPSSecure- - GPS Tracking
  6. #16
    Aug 1999
    Washington D.C.
    Quote Originally Posted by Confused
    No. It has a user selectable jumper. Standby power is enabled by default, but removing the jumper will disable standby power. This choice is yours.
  7. #17
    Aug 1999
    Washington D.C.
    Quote Originally Posted by Nic
    This only applies to the OPUS 90 watt.
  8. #18
    Aug 2003
    Essex, England
    Quote Originally Posted by Zip-Lock
    Ah, OK, knowledge bank updated
    Cheers, Zip-Lock
    Garry
    www.aimee.cc
  9. #19
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    thats what i ment, should have put in more detail eh? :P
  1. Replies: 8
    Last Post: 06-05-2004, 11:13 AM
  2. WTB: Opus 90W or 150W
    By Vandyll in forum Classified Archive
    Last Post: 05-17-2004, 12:47 PM
  3. WTB: Used or New Opus 90w or 150w
    By antimatter in forum Classified Archive
    Last Post: 01-14-2004, 07:09 PM
  4. Opus DC-DC 90W 150W Pricing Dimensions Info
    By Linus in forum Power Supplies
    Last Post: 10-15-2003, 04:29 PM
  5. Opus 150W or 90W for this setup?
    By ugosplat in forum Power Supplies
    Last Post: 07-04-2003, 09:35 AM
