Results 1 to 10 of 19
Thread: opus 90w Vs. 150w
    Jul 2004
    opus 90w Vs. 150w
    hey guys,
    sorry for the noob question. is the only difference here the amount of power and thus how many devices on your pc u can run and also the length of time the computer can be left on in hibernation before it shuts down?
    thanks in advance for your input!
    sang
    Aug 1999
    Washington D.C.
    Generally if you are using an ITX motherboard go with the 90 watt. If you have a full sized ATX motherboard then go with the 150 watt. List your componients and I can give a more accurate recommendation.
    It can say indefinitely in hibernation because that is a full shutdown and doesn’t use any standby power.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    There is one other 'slight' difference. The 150W ALWAYS provides standby power on the +5VSBY output--consistent with ATX specifications. Depending on your configuration this can cause problems and/or eventual battery drain. The 90W let's you enable/disable this feature with a jumper.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    I believe your USB devices could still draw a little power, so the opus could still be supplying a little voltage even when the PC has shut down. The Opus is supposed to shut down completely once your battery drops to a certain level so as not to drain the battery. Some has reported trouble with this feature though. I suspect this is uncommon though.
    As a general rule, unplug the opus if you're leaving the car for an extended period of time.
    Aug 1999
    Washington D.C.
    Quote Originally Posted by pip
    That would be the standby power you are talking about. With the 90 watt OPUS it can be disabled. If it is disabled the OPUS won't drain your battery if left for a long period of time.
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Quote Originally Posted by Zip-Lock
    Ah, I have a 150w Opus - are they different in this respect then?
    Aug 1999
    Washington D.C.
    Yes, very different. The 90 watt has a jumper to disable standby power. That means it will fully cut the power to the board when shutdown.
    Mar 2004
    Redondo Beach, CA
    Is there an echo in here?
    Low Bitrate Udonboy's Avatar
    Aug 2004
    Anaheim, CA
    About how many things can you connect up using a 90W opus? Right now I'm in the planning stages and I don't know if I should get a 90W or a 150W opus.
    Here's what I'm thinking of running:
    VIA EPIA M10000
    Segate 40GB 5400 rpm
    512MB PC2100
    Toshiba CD/DVD-ROM
    Lillput 7" TFT VGA
    AutoEnginuity Scantool
    some GPS unit
    and possibly a FM/TV Tuner.
    I'll prolly hook up a USB hub up to this too. It sounds like alot of stuff to me. Will a 90W do it?
    FLAC Chairboy's Avatar
    Jan 2004
    You should be able to use the Opus 90. For some numbers, check out the calculator on the mini-itx.com website:
    http://www.mini-box.com/powersimulator.html
  1. Replies: 8
    Last Post: 06-05-2004, 11:13 AM
  2. WTB: Opus 90W or 150W
    By Vandyll in forum Classified Archive
    Last Post: 05-17-2004, 12:47 PM
  3. WTB: Used or New Opus 90w or 150w
    By antimatter in forum Classified Archive
    Last Post: 01-14-2004, 07:09 PM
  4. Opus DC-DC 90W 150W Pricing Dimensions Info
    By Linus in forum Power Supplies
    Last Post: 10-15-2003, 04:29 PM
  5. Opus 150W or 90W for this setup?
    By ugosplat in forum Power Supplies
    Last Post: 07-04-2003, 09:35 AM
