Results 1 to 8 of 8
Thread: anyone seen/used this before (60W Car Power Kit)
    Aug 2004
    I have come across this, and to me seems perfect (i am not bothered about the auto power features offered by the OPUS)
    http://www.morexintl.com/60W%20Car%20Power%20Kit.htm
    It says it can operate between 9v and 16v with a 12v regulator supplied, to me this woudl meant it would probably be able to surive a crank??
    Basically I am too cheap to buy a OPUS and want the next best thing (but not an IPTS).
    Your opinions please.
    Paul
    Variable Bitrate proTONEd's Avatar
    Jun 2004
    Belgium
    I think you are right. Probably it won't survive crank, I'm not even sure if it will boot upon ignition like the ITPS.
    But you might look into the Carnetix powersupply. Actually the Carnetix is a not a powersupply but it is a powerregulator and startup/shutdown controller in one. Something like the ITPS but with the features of an Opus.
    But i don't know how much it costs, you might find some further info here on the forum.
    Why is it drug addicts and computer afficionados are both called users?
    Currently : Audi A6 - no install
    Second install : VW Passat '97 CarPC
    First install : '87 Audi 80 CarPC
    Aug 2004
    in order to get it to boot with ignition i've got a few relays i plan to use that are controlled from the acc line to auto power on - one feature i really want is for the pc NOT to shut down on power off, and have being able to create a setup that will allow this, while also allowing ign start up.
    Why don't you think it would survive crank? my batt drops to 10.1v on crank every time (even from cold start) so if it can handle 9v input surely it will work, or am I missing something?
    Thanks for the reply
    Jun 2004
    Sydney, Australia
    I have that kit and it does survive crank. It does everything apart from the auto on/off, but i plan on making my own some day anyway (at the moment i just hit the power button when i want to turn it on).
    Aug 2004
    Quote Originally Posted by Dominik
    how do you power your setup? directly off battery? that was my plan, and as i said above i'd have a setup for an IGN start power up, and manual power off. you get yours from mini-itx.com?
    Jun 2004
    Sydney, Australia
    Actually i am in Australia, and i bought mine from a local shop (cheaper/faster delivery). Its wired to the battery; i ran a thick power wire from the battery for my Sub amp and it piggybacks off that...
    Interestingly its the shutdown that i am more interested in automating! (maybe its because i am so forgetful!)
    Jun 2004
    Belgium
    Quote Originally Posted by Paul_
    In some cars the voltage does drop below 9V, as long as you stay above that, there will be no problem. Was just assuming worst case scenario
    Variable Bitrate cheerio's Avatar
    Jun 2004
    San Antonio
    really i think it depends on your battery and how many cold cranking amps it can provide to you. And if your voltage is dropping really low, for me i found that it helps to turn my radio off (it turns both of my amps off as well) about 5 mins before i park it. Car even starts faster
  1. Replies: 9
    Last Post: 06-08-2006, 05:15 PM
  2. Someone has truyed E311 Mini-ITX Car power supply?
    By Goose in forum Power Supplies
    Last Post: 09-16-2004, 04:54 PM
  3. morex car power kit vs. ITPS
    By NaFooEsi in forum Power Supplies
    Last Post: 06-16-2004, 12:51 PM
  4. FS: Morex Car Power Regulator Kit (Brand New)
    By migel628 in forum Classified Archive
    Last Post: 04-06-2004, 11:26 PM
  5. About power Supply to PC in car
    By Sk8te in forum General Hardware Discussion
    Last Post: 11-11-2000, 10:39 AM
