Results 1 to 5 of 5
Thread: Which devices should I power with the OPUS?
    Dallas (Grapevine)
    I am getting the 150watt OPUS most likely. Just wanted to know which parts of the system I should use the 'clean' OPUS power for (as compared to using the cars' standard 14vdc power). Skipping the obvious PC and drives I can think of:
    1. Xenarc screen
    2. head unit (Alpine HU)
    3. Amps
    4. fans (to keep carpc cool)
    5. line drive amplifier
    6. ODB2 tool
    7. powered USB hub
    8. XMPCR
    9. DAC's (digital to audio converters)
    Thanks for the help here...
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    I'd wire up the following to the Opus.
    1. Xenarc screen - gives you a totally clean picture!
    4. Fans - these aren't taking up much power
    7. Splice into the 5V line for this
    8. XMPCR - Then it will turn on/off with the PC
    The rest i'd hook up to the battery, and switch them on via the ignition.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Aug 2004
    Atlanta Ga
    Quote Originally Posted by Confused
    Garry
    I installed my Opus 150 yesterday. I have it connected to a Morex 3677/Intel Celron 2ghz/slimline DVD-CDRW/notebook HDD, it would be safe to power my lilliput 7" from it also?
    I've got to re-run some power cables I inadvertantly ran along with the rca and vga/usb cables, that would be a good time to change the power source for the monitor.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Quote Originally Posted by m_dunnie
    You should be able to hook up the lilliput without too much difficulty.
    Dallas (Grapevine)
    thanks for the reponse!
  1. opus power supply question
    By septicdeath in forum Power Supplies
    Last Post: 07-08-2004, 04:25 AM
  2. Fs Opus 150 Power Supply
    By vp911 in forum Classified Archive
    Last Post: 06-07-2004, 06:05 PM
  3. No power output on Opus
    By Vandyll in forum Power Supplies
    Last Post: 05-31-2004, 10:11 PM
  4. Will a 150W OPUS power this?
    By mbkowns in forum Power Supplies
    Last Post: 04-14-2004, 03:17 PM
  5. Opus power cord
    By mikeyg35 in forum Power Supplies
    Last Post: 04-02-2004, 08:48 PM
