Results 1 to 5 of 5
Thread: huge power issue, HELP
    Newbie smonice's Avatar
    Aug 2004
    Jersey Shore
    ok so here is what happened. i wired a +12v line from the battery to inside the car and then up to the lilliput touchscreen screen. here are the voltages i saw:
    car off: 12.9 before lilliput inline regulator, 12.4 after (closer to screen)
    -light would come on but would not power screen up fully
    car on: 13.9 before, 13.4 after
    -still not working
    so i took out the regulator and ran the wires right from the battery line to the screen and had 13.9 into the screen.
    it worked fine now. is there a problem with doing it this way, without that inline reg from lilliput.
    any idea what the problem could be with the inline reg???
    thanx a ton!!
    smonice
    Mar 2004
    Montreal, Qc.
    What kind of regulator? Check the ground on the Regulator.
    VWMAN
    "Live Long And Prosper"
    car: VW Cabriolet '90
    puter: M10000(toasted), Lilliput, CarNetix
    status: In Progress
    Aug 2004
    Jersey Shore
    it was the regulator that comes with the lilliput (egg).
    Low Bitrate l9nux's Avatar
    Aug 2004
    San Francisco
    I'd be carefull of bypassing the regulator (egg), as your car voltage whilst it reads 13.9 could easily spike to 16v or higher and damage the Liliput. If the regulator is broken then I'd get a new one before you need a new TFT.
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Quote Originally Posted by smonice
    -still not working
    thanx a ton!!
    smonice
    Make a dc-dc converter to help the problem
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 06:10 PM
  2. Simple Idea for keeping power to inverter while cranking....
    By syclone477 in forum Power Supplies
    Last Post: 03-23-2004, 09:03 AM
  3. Opus 90w Power Action
    By EBoundEE in forum Power Supplies
    Last Post: 03-10-2004, 09:11 PM
  4. Brief power loss between ACC and start
    By Destin in forum General Hardware Discussion
    Last Post: 01-26-2001, 10:12 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 09:33 AM
