Results 1 to 10 of 17
Thread: Stupid question about OPUS wiring
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Well, my OPUS 150 watt PSU is ordered and should be here in a day or two. I went out to walmart and bought a 200 watt amp. wiring kit for 10 bucks, I figured this would help with running power to the carputer.
    However, when looking at it, I realised that there is only one wire meant to come from the battery (+) to the amp (or OPUS in this case), and then a 2 foot grounding wire is meant to be used for the ground.
    Anyway, how exactly should I wire the OPUS? Obviously it will have a 12v positive and a negative, should I just run the OPUS's 12v + to the battery's 12v +, and then ground the OPUS's - to the frame of my car? Or am I going to have to run a wire all the way back to the battery's negative terminal?
    Constant Bitrate SuzukiAerio's Avatar
    Aug 2004
    PA, USA
    It is my understanding (through testing) that you only need a good ground and need not run it back to the battery. (someone will correct me if i am wrong im sure)
    What I did was ..... removed a BIG screw that held the back seats in place and grinded the paint off the screw and the area around the hole the screw gets secured to.
    Then I tested the conductivity of the connection and it worked fine.
    It was alot easier this way ..because now I only have 1 wire running from the bat and the other is only about 12 inches long from the screw already in the trunk to the ground.
    Hope that helps
    Low Bitrate swingpoha's Avatar
    Jul 2004
    The ground wire should be as short as possible, meaning DO NOT run it back to the battery's negative find a connection to the frame of the car as close to the opus as possible.
    My obligatory progress meter.
    [|||||||||||||||||||-] = 95%
    Basic Install done and all bugs fixed.
    Need: GPS, OBD
    Aug 2004
    Springfield, MO
    Alright, thanks a lot for the replys guys. That's what I was thinking, just wanted to make sure I didn't fry anything by hooking it up wrong.
    One last question, and I think I'm good to go. A 20 amp fuse is plenty for powering a carputer plus a 7" lilliput, correct?
    Aug 2004
    PA, USA
    I currently have a 50 self resetting circuit breaker coming directly off my battery and mounted under the hood ( This part has been completed already) This will break the whole system in case of a large draw/jolt.
    I plan to adda few "inline fuses" to break components as deamed needed by thier rating.
    not saying you are righ or wrong .... just my plans.
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    According to the opus setup info, you ARE supposed to run a wire to you neg terminal, and your possitive terminal on your battery. But who really follows instuctions....
    BossTone74
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    I think a 30A fuse is needed.
    May 2002
    Japan, Oregon
    That would be a 30amp fuse ....over...did I hear a niner in there?
    BossTone74
    Aug 2004
    Springfield, MO
    Ack... The amp wiring kit I bought came with a 20 amp fuse with 12 guage wire...
    Can I just buy a 30 amp fuse for it, or will 12 guage not handle that? Time to move up to 10 guage?
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    Are you powering the amp and opus seperatly?
    I use a 15A fuse on my opus.
    CarPC status: iPod, 3,456,217 songs so **** you
  1. OPUS Wiring
    By ikhonlord in forum Power Supplies
    Last Post: 08-24-2004, 08:00 PM
  2. 2699 case with opus 90w power supply question
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-04-2004, 02:32 PM
  3. Specific Opus wiring question
    By rdc_3200 in forum Power Supplies
    Last Post: 07-24-2004, 05:12 PM
  4. Replies: 1
    Last Post: 05-01-2004, 06:17 PM
  5. wiring question about the opus 90w
    By DSM97RS in forum Power Supplies
    Last Post: 03-28-2004, 09:28 PM
