Results 1 to 10 of 10
Thread: pw-70 & m10000 - boot problems
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    When i boot my m10000 with the pw-70 power supply (just one hd connected, nothing else) it hangs up in the bios. It recognises the ram, but when it is supposed to scan the ide channels it just hangs up =s
    I've tested with a normal 230v power supply, and it works fine.
    Any suggestions what the problem may be?
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Common sense would say bad PSU?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Variable Bitrate brooksware2000's Avatar
    May 2004
    Minot AFB, ND
    is your HDD 3.5" or 2.5". It may not like the 3.5" drive if that is what you are using. Try hooking a floppy drive up and boot to a boot disk and see if that works.
    Check out my hopefully useful site...
    www.hobbybotics.com
    It's still under design but it is functional
    Jul 2004
    Sweden
    I'm useing a 2.5" hdd...
    Jul 2004
    Sweden
    Okay, now I've tested the pw-70 with another mobo, but with same harddrive. Guess what? It worked. But it still doesnt work with the m10000.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Sounds like a bad mobo, or possibly just a bad connection.
    Jul 2004
    Sweden
    Dou you think so? What could be wrong? No to be rude, but it works fine with a normal powersupply =S
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    I had a problem booting my M10000 when my car was running and alternator was putting out 14.5 volts. I had to put in an ITPS to get it down to 12 volts to work when it was running. I could get it to boot/run without my truck started.
    Jul 2004
    Sweden
    Well, now I've done some testing. The problems is with the harddrive, havent figured out what it is yet thou. If i boot the m10000 with the pw-70, but connect the harddrive to another powersupply, it works perfekt. But it still hangs up when i boot with the hdd connected to the pw-70.
    Its not a problem with the input voltage, since I'm running it with a 230v - 12v powersupply, and then connect the pw-70 to it. (Testrunning on my livingroomfloor ) I get exactly the same voltage with both the pw-70 and the atx powersupply.
    Apr 2003
    Check the Slave/master jumpers on your motherboard. A conflict with the jumpers usually causes hangups on boot.
  1. Strange M10000 problems
    By cyber in forum General Hardware Discussion
    Last Post: 03-04-2005, 01:10 PM
  2. problems with M10000 and WD 80GB HD
    By wyckyd in forum General Hardware Discussion
    Last Post: 08-05-2004, 01:33 PM
  3. GF FX5200 in M10000 wont boot
    By stimps in forum Power Supplies
    Last Post: 07-31-2004, 11:28 AM
  4. boot problems
    By tracker92 in forum General Hardware Discussion
    Last Post: 05-20-2004, 03:21 PM
  5. Problems with new EPIA M10000 Setup
    By nirvanades in forum General Hardware Discussion
    Last Post: 04-30-2004, 05:11 PM
