Results 1 to 6 of 6
Thread: Call me stupid....Basic opus instalation questions
    Daytona Beach FL
    Finally got all i need to install my incar PC
    I ordered and opus and it comes with no paperwork whatsoever and there website has only basic descriptions....
    Im sure i could guess and get it right, but i dont think its smart to take a chance of blowing up a $200 PS and $700 worth of computer when i could just ask.
    How do you wire it?
    -Red wire? Power? I search and found this obviously is wired to the battery with a 30a fuse
    -Yellow wire? is this the ignition wire? OR is this the power wire?
    -Black im pretty sure is ground, and i can figure where that goes
    Now it came with some jumpers, i assume these are to controll the shut down timer...where do they go?
    Anyother tips for installing this please feel free to add. or possibly a link to the setup instructions
    btw...i ed
    Super Moderator xBrady's Avatar
    USA
    Red wire = power
    Yellow wire = Accessory (so it knows when your car is turned on/off.
    Black = Ground
    Jumper is for the shutdown controller. If you want to put that on you have to open up the power supply and there is a place to put the jumper. With the jumper off it will shut down after 10 seconds (default).
    Tip: if you have an Amp that is already wired to the battery, acc., ground, you can just tap into that.
    There is a manual in PDF format that you can get. Search the forums for it. I know several people have posted a link to it. I just don't have time to look right now. Good luck!
    Installed.
    -GPSSecure- - GPS Tracking
    Variable Bitrate Curly_cat's Avatar
    Jun 2004
    Ipswich, UK
    The OPUS I have here has Red, Black and Blue input wires.
    Red = Power (Constant)
    Black = Ground
    Blue = Ignition (Switched Power)
    If they have change the blue to yellow, it should be the same.
    Email me and I will send you a PDF copy of the instructions.
    BTW is it a 90W or 150W OPUS?? Just to make sure I send the right copy.
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
    Daytona Beach FL
    Quote Originally Posted by Curly_cat
    Black = Ground
    Thanks guys,
    its an opus 150w
    Its-simple@juno.com
    THANKS!
    Constant Bitrate snmnetwork's Avatar
    Aug 2004
    Atlanta, Ga
    OPUS 90W - please help me identify this cable
    This should help you. It helped me
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    http://www.mp3car.com/products/SFX_D...uide-Rev_C.pdf
    the manual is listed in the products section of this site
    Signature: [==||========] 20% complete
  1. Stupid question about OPUS wiring
    By RS3RS in forum Power Supplies
    Last Post: 08-31-2004, 02:33 PM
  2. BASIC QUESTIONS - Read this first!
    By zorro in forum PhoneControl
    Last Post: 07-25-2004, 06:22 AM
  3. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
  4. Replies: 0
    Last Post: 05-02-2004, 08:32 PM
  5. Some questions on what an Opus can do..
    By Banderon in forum Power Supplies
    Last Post: 12-09-2003, 01:43 AM
