Results 1 to 5 of 5
Thread: Anyone put an Opus inside the case?
    lbk
    lbk is offline
    Feb 2003
    Chicago
    I have Cubid 2688 case, that I put my Opus power supply inside of. Tooks some hacking of the cradle for the HD but that didn't matter since I use a laptop HD and didn't need that much room. Anyway I have it all mounted, and I used the standard fans that come with this case blowing across the Opus power supply.
    Anyone else done this and been using it for a while? If so any problems with heat?
    Note the biggest difference is that these are two small fans as opposed to the single larger fan that comes with the opus, plus they are blowing across not down onto the Opus like the stock Opus fan.
    I'm not putting too much of a load on it I have the 150w version of the Opus and I only use a laptop DVD drive, laptop HD that's it. My GPS is powered directly by the car, and so is my screen.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    I did that in my case, not had a single problem.
    A few others have done this too
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Yup, mounted mine on the side wall of my Micro-ATX case using nylon standoffs. I used velcro to position the fan to blow air over the supply. Works fine (if only it'd turn on the Biostar!)
    lbk
    lbk is offline
    Feb 2003
    Chicago
    Great thanks, I didn't think it should be a problem but wanted to make sure I wasn't the only one doing this. I like that EVERYTHING is inside the case now it goes under the seat and then it's just connections for audio, display, touch, and GPS. Makes it easier if I need to take it inside for anything.
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    I did the same w/ my case (Q Box or Q Box 2. had to cut a bit - mounted 2 fans inplace of old PSU, mounted Opus on piece of lexan cut to fit into hdd bay. use laptop hdd.
    I hada slight problem with mine, but I don't know if its vibration, disk speed, or heat.
    All my problems began when I upgraded to a 7200 RPM Laptop HDD. (I hada 5200) the pc started to lock up and hdd would fail on boot (no boot device found...) It seemed like the system would freeze if I hit a bump in the road... but when I would try a reboot , it would not come back up. Finally I laid down the back seat to get some ac into the trunk area, and then the system came up fine.
    I dono. Maybe the heat combined with the faster drive made it more sensitive. I sold the car and am working to finsih my new system right now. everything fits under the drivers seat, so heat should not be a problem.
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
  1. Travla C137 & OPUS & ITX P4
    By craigyb in forum General Hardware Discussion
    Last Post: 11-13-2004, 10:51 AM
  2. Opus....overheating...?
    By dapepster in forum Power Supplies
    Last Post: 07-12-2004, 02:08 AM
  3. OPUS in a C137 case
    By craigyb in forum Power Supplies
    Last Post: 06-27-2004, 02:42 PM
  4. Consider not building a case for Carputer
    By antimatter in forum Fabrication
    Last Post: 05-20-2004, 01:00 AM
  5. Opus Users: What case are you using?
    By bambooracer in forum General Hardware Discussion
    Last Post: 03-09-2004, 10:02 AM
