Results 1 to 7 of 7
Thread: 2003 Accord power supply help!!!
    Jul 2004
    I need some help with powering my PC to my car. Has anyone done a 03 accord? I need to know what would be the best way of bringing power my pc and the Xenarc. I will put the pc in the trunk. Is there a diagram out there? What wires can I use going into the ignition? What all do I need for this process. Or do I have to go through the firewall to get to the car battery to get my power.
    Any help would be appreciated.
    Elsewhere
    Quote Originally Posted by Google
    Your best bet: Use the function to see what other users have done. I don't know if there's an '03 Accord, but I know for a fact there are other users with systems in Hondas.
    As far as power, there are two schools of thought:
    Use a standard AC-DC power supply (any PC you buy will already have one) and a power inverter.
    Pros: Cheap and readily available
    Cons: Inefficent, may not survive crank
    Use a DC-DC ATX-spec power supply. The two most common are from Opus or the Maestro Sproggy.
    Pros: Efficient, survices crank, auto-on/off with ignition
    Cons: Expensive.
    How about the Wiki?
    Jul 2004
    I do have a Opus 90W that I plan on using. But what is all that I need to buy and should I get power from the ignition or the battery itself. How do I get the cable throught the firewall?
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    Probably want to pick up and amp installation kit to run the power to the trunk-I'll give you a fuse and heavier (4 or 8 guage wire and connectors). Most firewalls will have a rubber grommet that you can use to run your wire into the cab. Another route to get power into the trunk is to run it under the car and find a way to get it into the trunk towards the back of the car. Don't know about Opus specifics, but I'm guessing you'd run a heavier guage constant power and a lighter guage switch/accessory wire to the Opus.
    FLAC ppgt94's Avatar
    May 2001
    USA
    You can run a ACC line from the fusebox.
    Jun 2000
    NYC
    I have a 99 accord there is an area below the driver's dash where cables can be run though from the battery. I'm assuming a 7th generation accord wouldn't be much different. Also, honda are awesome for routing wires, everything pops off easily.
    Jul 2004
    Can anyone post some pics?
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
  3. 350 watt power supply
    By MasterJacko96 in forum Power Supplies
    Last Post: 01-20-2004, 05:01 PM
  4. Alright, Gonna make my own power supply.
    By crazydemon in forum Power Supplies
    Last Post: 01-18-2004, 06:36 PM
  5. AT power supply questions
    By JustAGuy in forum General Hardware Discussion
    Last Post: 07-26-2000, 05:35 AM
