Results 1 to 10 of 11
Thread: Multiple Turnon Sources To Relay
    Aug 2004
    Newbie here :-) First post.
    I was wondering if anything bad would happen if I gave power to my inverter through two different relays. Actually running the outputs from them in parallel. I wouldnt think anything bad would happen, but i'm just making sure.
    I'm doing this because I want the inverter to be on if at least one of the two things are happening. (Power from Ignition, and Power from Power Supply).
    This way, when I use the 'fake UPS' method to hibernate the PC, the Inverter wont shut off until the PC is shut down.
    Thanks In Advance!
    -Tim
    Aug 2004
    After researching more ( .... doh! )
    I realized that I can accomplish the same thing with one relay, but instead using two diodes on each of the turnon lead's (from pc powersupply and accessory line)
    Mar 2004
    Vancouver, BC, Canada
    Here is a thread: Looking for a creative solution: USB bus still powered after CPU is off
    Look at post #78.
    Might help.
    Aug 2004
    link doesnt work :-\
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    The question would be: where does one get a diode big enough to handle, say, 100amps at 12v?
    Funny, I decided to use exactly the same thing last night...two relays from ignition and Opus output. This is to switch it off completely while the system is shut down.
    Sep 2003
    Vic. Australia
    open up your inverter and wire the relay over the switch you currently use to switch it on and off. This will only draw a small amount of current and allow you to use a smaller relay and not have to worry about big diodes etc.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by GWRedDragon
    Why on earth would you need a diode that big?
    Diodes are on the relay coil. Relay switches permanent feed. Two switching signals go through low power diodes to the coil. What's the big diode for?
    Mar 2004
    I fixed the link in my earlier post.
    Aug 2004
    thanks for all the tips/comments. now its time for some experimentation.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by timothy0605
    Thanks In Advance!
    -Tim
    I have mine set up exactly like that. Works fine for me. One relay off the 12v carputer supply, the other is actually is hooked to my amp switch off of my headunit, which is also hooked to a cube timer as well. Turn off the deck, it sends a signal to turn off carputer. Carputer shuts down, kills power to inverter. Power up deck, restores power to carputer, carputer powers up. Yeehaa.
    Tidder
    Try RevFE
  1. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 04:05 PM
  3. Queston conerning stinger 200 amp relay
    By vash in forum General Hardware Discussion
    Last Post: 05-25-2004, 11:15 AM
  4. 12V relay + diode question
    By cybermob2 in forum Power Supplies
    Last Post: 05-18-2004, 01:11 PM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
