Results 1 to 2 of 2
Thread: Opus 90 wiring supplied
    Newbie petera's Avatar
    Nov 2003
    Can I connect a heavier gauge wire to the already wired Opus 90 that I purchased.A Red,Black and Blue wire is prewired into the connector and rather that dismantle the plug I intend to connect a heavier gauge wire to all points except the ACC Blue Wire.Will a change in fuse rating become an issue
    Aug 1999
    Washington D.C.
    You can but it won't make much of a difference for such a short wire run. It would be sufficient if you just ran the 8 gauge right up to the "pigtail" connector supplied with the OPUS.
    One of the reasons to use a thick wire is so that you don't get voltage drop over a long wire run and also so that it can supply a lot of current during low voltage conditions such as an engine crank. It won't change the fuse rating.
  1. OPUS Wiring
    By ikhonlord in forum Power Supplies
    Last Post: 08-24-2004, 08:00 PM
  2. Replies: 4
    Last Post: 08-11-2004, 07:07 PM
  3. OPUS 150 watt now in stock in the official mp3car store!
    By Zip-Lock in forum Power Supplies
    Last Post: 06-24-2004, 07:56 AM
  4. FS: 90 Watt Opus PSU and remote wiring kit
    By EBoundEE in forum Classified Archive
    Last Post: 06-01-2004, 09:54 PM
  5. Opus 90 Watt Wiring Questions
    By EBoundEE in forum Power Supplies
    Last Post: 09-29-2003, 07:31 PM
