You'll probably need to run power from the battery because most cig lighter sockets can't handle the necessary power (most can provide about 120w).
The problem with power inverters is that they add another large box to your power system which is really unnecessary. Most of them can't survive engine cranking, and you'll also need to ground both the inverter AND your computer case so they won't be ground noise in your audio.
The ITPS makes a good shut-down controller and you can find more about them by searching on this forum.
LinkBack URL
About LinkBacks
i used an inveter, had no problems at all
