Results 1 to 7 of 7
Thread: 12V, 5A Regulated Car Adapter
    Oct 2003
    Smile 12V, 5A Regulated Car Adapter
    I've been looking for a source of a 12V, 5A regulated power supply for using my Xenarc MP-SC1 and Lilliput in the car. Xenarc tech support claims that unregulated automotive power (at 13.8 to 14.4V) can kill the computer. I tried the adapter sold by Action Replay and even though it is rated 12V, 5A, it trips when the computer powers up (there is a very short current spike when the unit powers up that causes the adapter to trip). The AC adapter sold with the Xenarc is rated 12V, 5A but doesn't trip. Xenarc doesn't have a dc car adapter for this unit and suggested using my ac adapter with an inverter. Not very elegant and too many wires.
    After a lot of looking, I found Lind Electronics. They make "rugged" power converters and car adapters primarily designed for police-type applications. They custom-made me a 12V, 5A adapter that works perfectly. The unit says it will take 11 - 16V input. But, it seems to be better than that since my computer will survive a crank, even with the headlights on. Wow.
    The unit is a bit pricy, but in my opinion well worth it. The output is running about 12.5V and is rock-solid.
    If you are interested, see www.lindelectronics.com. The part number for the Xenarc is XE1250-1321X. It cost $99. I had it in 4 days after I placed the order (Minnesota to South Carolina). They can configure the connectors for your application. I spoke with Dean when I ordered it.
    If you want more info, let me know.
    Alta
    Aug 2003
    Moncks Corner, South Carolina
    hey Alta where in SC are you?
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    If they ever get them back in stock another good option is the Carnetix CNX-P1260. It has the same 5 amp rating and comes with built in shutdown/starup controller. My case came with a Morex power supply so back when I built mine I ended up buying and ITPS and adding voltage step up module off Ebay. I step up the voltage that I feed the ITPS so that when the car isn't running I still get the 12 volt output inspite of the 1.5 volt loss. My pc will survive a crank now, but using the ITPS as my startup/shutdown controller makes this pretty insignificant since the ITPS cuts off power after a short period automatically.
    Mar 2004
    Vancouver, BC, Canada
    I run my LCD off the power from my PSU.
    Jan 2003
    Ruston, LA
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Variable Bitrate looneeii's Avatar
    Feb 2005
    Gatineau, QC, Canada
    Quote Originally Posted by Alta
    Alta
    So will the AC adapter power the PC and TS adequately if used in the cigarate lighter?
    99 Grand Prix Grand Tigress
    HW
    Liliput 8in TS
    845GVD MITX w/ 2.4 Mobile P4M (478 MB)
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Quote Originally Posted by frodobaggins
    Grab it from here
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  1. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 10:11 PM
  2. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 01:47 AM
  3. 12v Regulated at 3A
    By doig in forum Power Supplies
    Last Post: 09-21-2003, 08:10 AM
  4. Car Stereo Installation Video's for Sale
    By johnram in forum Classified Archive
    Last Post: 09-05-2002, 11:27 PM
  5. playstation in car with an mp3 adapter
    By johnnystorm in forum General Hardware Discussion
    Last Post: 05-06-2000, 04:56 AM
