Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 62
Thread: Cutting power to USB after computer has shutdown
  1. #11
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    do usb devices really use enough power to drain a battery?
    YES, if you don't start your car every day. The motherboard standby takes power too!
  2. #12
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I think that there is an option in the bios that disable power to USB.
  3. #13
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    well ****
    that may be why my car battery keeps dying....
    im not really competent with making circuits and things; should i just sell my 150w and get a 90?
  4. #14
    Aug 2004
    Arlington, VA
    Build the relay mod. It's not that hard, really.
  5. #15
    Jul 2004
    Berkeley, CA
    http://support.microsoft.com/?kbid=315664
    No need to sell your 150w
  6. #16
    Aug 2004
    Arlington, VA
    Quote Originally Posted by 0l33l
    Uh, the problem has nothing to do with software
    The Opus 150w keeps the standby power going at all times.
  7. #17
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by GWRedDragon
    That link I gave says how to turn off USB devices when the computer is off. That will save power.
  8. #18
    Aug 2004
    Arlington, VA
    Isn't that setting on by default, in Windows? I don't really buy it, but I'm not sure why I'm skeptical
  9. #19
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Get out your meter and take some measurements before and after; then post back your results. The M10k with no USB devices attached will burn about 86mA (measured at the Opus 12V input) when off.
    IIRC, this was discussed before and there is not a known BIOS patch to disable the power consumption of the mainboard. Depending on your setup, the info in the MS link may make your situation better but it probably will not solve the problem. Ultimately, it depends on what your power consumption goals are.
  10. #20
    Jul 2004
    Berkeley, CA
    You're right. It won't completely solve the problem, but it will reduce the power consumption. I'm gonna guess that there is going to be a hack for the 150w opus
  1. Replies: 0
    Last Post: 06-14-2004, 11:36 PM
  2. power to USB stays on during hibernate
    By ob1 in forum Power Supplies
    Last Post: 04-14-2004, 10:53 PM
  3. Will this power a computer?
    By Vicked in forum Power Supplies
    Last Post: 11-11-2003, 08:40 AM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  5. portawattz 140 wont power up my computer....
    By TimW in forum General Hardware Discussion
    Last Post: 04-10-2000, 09:14 PM
