Results 1 to 5 of 5
Thread: Not the ACC Wire....
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    i was wondering is there a wire that is only on, when the Engine is on. Not the ACC wire as that can be on when the engine is off. I want a wire that is only live when the engine is actually working. Something like the IGN wire or thereabouts, so I can hook up a relay safely to it.
    Fox Mulder
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Xenarc 700TSV TS BU353 DiNovo Mini Car2PC ODBII Bluetooth HF 16x2 Character LCD
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    You should be able to find something in the charger cirquit (regulator)... or build something around the system that makes your "alternator"-light go off when the engine runs...
    Jul 2004
    Tach wire.
    Maximum Bitrate eugenen's Avatar
    May 2002
    Depends on the vehilce, newer ones have a dozen or more fuses or relays that have power in the run section. The SUV body based off my truck has a rear defroster that gets power on run only and since I don't have a rear defroster i tapped off of there.
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    Try the accessory power vs the cigarette lighter... I have a jeep liberty which has a cigarette lighter which is switched (hot when ignition is on) and the accessory connector (spare cigarette socket for running accessories like powered pump etc) which is hot all the time.
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads:
  1. In search of an ignition wire
    By witten in forum Power Supplies
    Last Post: 07-27-2006, 01:29 AM
  2. Replies: 37
    Last Post: 05-17-2004, 07:01 PM
  3. ACC Wire Dead!
    By bambooracer in forum General Hardware Discussion
    Last Post: 03-29-2004, 04:25 PM
  4. Need to find acc wire that stays alive during crank.
    By Bobby Digital in forum Power Supplies
    Last Post: 02-05-2004, 05:42 PM
  5. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 10:58 PM
