Results 1 to 3 of 3
Thread: Morex 80w PSU not working?????
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    I'v just hooked up my morex 80w psu and it doesnt seem to work
    When i hit the power button on the motherboard i heer a noise WINE but nothing happens
    I hooked it up as the instructions says (instructions didnt say much)
    i have the 12v into the power supply by the lighter socket and then i have the ATX cable from the PSU to the motherboard.
    Im using a ITX MII 6000 with a 600mhz fanless cpu so its not draining to much it wont start.
    They only have a 60watt car psu on there website
    That is what i got but the to power button wasnt on my sheet.
    Then there is this one about hooking it up to the battery
    It mentions the 4 pins on the board which i gather pin 1 and 2 go to the motherboard and pin 3 and 4 go to a button to turn on the PSU which turns on the Motherboard.
    I had it hooked it and flicked the motherboard switch then i pressed the 2 contacts on the PSU that says switch to the front and it didnt do anything
    makes a WINE noise when i push power on the motherboard and i pushed both contacts on the board where it says switch front panel but still nothing
    Does anyone have any idea?
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    My only comment at the minute is that if I understand you correctly you are not using the power switch, you are simply shorting across the two pins. I believe this needs a certain restiance rather than just shorting!
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads:
    Aug 2004
    But a power switch from the PC is the same as shorting.
    I just modifyed a CD audio cable for the soundcard to connect from the PSU to the motherboard and i use the other 2 wires to start the psu and mb as shown in the second PDF and all i get is a WINE noise still
    Im still just shorting the to wires to start it but i get the wine but i short the pins from the PSU which makes the wine noise which only happened when i made the motherboard start up so it seems like the cable does make the motherboard switch go but it just wines nothing else
    On the DC hub a guy mentioned that the WINE noise could be that there isn't enough power through the lighter socket so i tryed it in another car and still the same so i dont know whats wrong maybe its a bad PSU ???
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. Morex 80W Car PSU
    By Tred in forum Power Supplies
    Last Post: 10-15-2004, 03:53 AM
  3. PW60 > Morex PSU?
    By Dominik in forum Power Supplies
    Last Post: 07-14-2004, 08:33 AM
  4. morex psu noise fix
    By starfox in forum Power Supplies
    Last Post: 03-15-2004, 08:19 PM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
