Results 1 to 10 of 16
Thread: OPUS to 22" LCD screen
    Aug 2004
    I have a Sharp 22" 16:9 LCD TV. It runs on 13v and 65watt. If I take 12V from OPUS and connect to the TV, will it work ? Will it break or burn anything ?
    Newbie sFischle's Avatar
    Jun 2004
    Germand
    I think thats not the best Idea, becaust 1st thing is that i don't think Opus provides 5,4 Amps on the 12V line.(Don't know the specs) And the other thing is that even if it would provide so much there would be not much left for other components like 3,5" Hard drives ore so on! Your Opus would be overloaded very fast!
    I would rather buy one of those DC-DC Laptop-Power supplies (from Ebay etc) which output constantly 12V and use this for the screen.
    Greets for Germany
    Fabian
    Aug 2004
    well the main question is, the transformer for the LCD gives out 13V to the LCD screen. If instead of using the transformer and feeding 12v power directly to the LCD, would it burn anything or should it work properly ?
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Quote Originally Posted by lookinco
    Whew... Might work... But man... That just seems like it would be risky.
    Any reason you don't just run to walmart and spend 15 bucks on an inverter? Seems like a much safer way to go to me.
    Plus, like he said, if you CAN power that thing off of the OPUS, you're not going to have much left over for the PC... Unless you have like an EPIA system with a single notebook hard drive or something...
    Still, I'd go the inverter route.
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    DO NOT FEED the 12V from your car directly to anything that was not design to be connected to a car electrical system.
    The power from a car is unregulated, meaning it can range from 7v to 16v. This will burn your LCD.
    You will always have to put something ( opus, notebook DC-DC, Inverter ) between the car 12v and the LCD to regulate the 12V.
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Constant Bitrate CHUPACABRA's Avatar
    Mar 2004
    G'ville S.C.
    I totaly second that!!!^^^^^^^^^^^^^
    2-15" ILO lcd w/DVI
    6800 gt Duel DVI out
    p4 1.6ghz flex atx board
    1gb 400 ram
    120gb(2-60gb raid) sata hd
    2-60gb hotswap
    WIN2K Pro SP2
    M.A.M.E. w/2,300 games
    CARPuter info
    Aug 2004
    I am running on an Inverter right now, but it make noise on the screen. I also know the power in my car is unregulated, that's why I thought of using an OPUS or other regulated power supply. I was just wondering if it would damage the LCD if i give it 12V instead of 13v.
    I am however planning to run TWO opus in my system.
    One for the CPU, motherboard, RAM, video card, and sound card, the other one for floppy drive, harddrive, DVD, USB hub and devices, a Xenarc 10" LCD, and MAYBE the 22" screen.
    Aug 2004
    Springfield, MO
    Ahhh, I see.. Have you tried any noise filters/conditioners or anything like that?
    With dual OPUS's, I'm sure that would help with power problems. Though I'd change the balance a bit. I'd imagine a 150watt OPUS would handel all of your computer stuff without a problem. Then you could have your 22" screen, the Xenarc and the USB off another one.
    I have all of this running on one OPUS with not a single problem so far:
    2.4 ghZ Celeron processor
    One stick of mem
    One 3.5 inch hard drive
    One CD drive
    One DVD drive
    My 7" lilliput touchscreen
    4 port USB hub
    So I'd imagine your whole computer would do fine on one of them, which can iliminate problems that can come up with running 1/2 your computer on one PSU, and ther other half on a different one (I blew up (almost literally, there was smoke) one of my old power supplys doing just this).
    Anyway... With the LCD rated at 13 volts, I can't imagine you'd do any harm by putting 12 volts through it. I can't really see how that could damage it, at worst, it just might not work right... Don't quote me on this, though, as I'm no electronics expert. I'm just saying, not putting enough volts through it is probably better than putting too many through it.
    Good luck, hopefully it will work out for you
    Aug 2004
    Speaking of which, would I have any problem powering my computer with two opus ?
    I probably can power my computer with just one, but if it case there's not enough power, say I need more power to run a DVD drive, could I just get another OPUS and connect the power plug to the DVD drive ?
    I used to run my DVD drive off an AC power supply and inverter, and my EPIa board off a morex DC-DC power supply, never ran into any problems, except when the inverter kicked the dust and overheated itself ><. If your going to use an inverter, make sure you get one with the right specs! A 100watt inverter will not run 300watts of power, just ask the slight burn hole it made in my tunk carpet a few years ago before I knew baout this stuff .
  1. Second LCD screen for my 3.5 year old son.
    By Nokia6600 in forum LCD/Display
    Last Post: 03-06-2004, 05:23 PM
  2. prob (white screen) with datalux m1023 and sharp lcd
    By Question in forum LCD/Display
    Last Post: 07-11-2003, 07:32 PM
  3. FS: 10.5inch touch screen lcd
    By V_C_F_666 in forum Classified Archive
    Last Post: 05-26-2003, 11:44 AM
  4. gamegear colour LCD screen useful??
    By asteroid in forum LCD/Display
    Last Post: 01-02-2002, 02:06 PM
  5. Wiring up full screen LCD
    By grandamp3 in forum General Hardware Discussion
    Last Post: 05-24-2000, 01:17 PM
