According to the Opus website the Opus 150 has 5a continuous on the +12v line...that's 60w. Does it use the 5v or 12v line?
Hi all,
I'm a new member
I'm trying to build a carputer using a microATX MB with
a XP barton 2600+ mobile CPU. This system can be
downclocked or overclocked it's depend on the power
I have.
But, The major problem I have is the power supply
I found one power supply with 400 watt but it's cost 300€/280$
so I'm looking for the opus solutions. My question is, can I use one opus
power supply for an AMD CPU working at 25 watts at downclocked
frequency and 50 watt at overclocked frequency?
I see the Ampere of the power supplies and does not appear suitable!
Please give me an indication/suggestions
the cpu is working on 3.3v and have 10A so the maximum power is 33 watts.....
not sufficient
I am using a XP 2600 but I had to underclock it because my motherboard doesn't have a place to plug in the 12v line.
Installed.
-GPSSecure- - GPS Tracking
Hi Brady
what mean "does not have a place to plug"????
I will use the soltek 75MIV2, so do you believe it's possiple to use the 150W
with XP 2600 + mobile at normal frequency?
I've used an Opus 150W with an Athlon-M 2600+ without difficulty.
Originally Posted by pip
Very interesting.............
your sign show XP 1600............ but
did you try also a mobile 2600 + with that carputer?
I dont think that is true, my xp mobile cpu uses the 12v of my psu (of my normal computer).Originally Posted by folagana
3.3v is not being used for cpu's, some motherboards use the 5v, some the 12v, the 3.3v isn't powerfull enough for cpu's like amd mobiles.
For the opus a simpele solution:
underclock it. Normally the 2600+ works on 1.933ghz with 1.45v. Lower the mulitplier and the voltage. Maybe 1.0ghz with 1.2v works stable, and if so: that wouldn't use much ampère (and watts)
If 1.0ghz would not be enough, then raise the multiplier, and the voltage a bit.
Newbee, sorry for my bad english. lol
Trying to built a carmp3 systeem
own psu: max788, pt5071, pt5024
See, that's what I thought too...but I figured I could be wrongOriginally Posted by PASware
I looked up your motherboard specs and it looks like it has a 12v input. You should be able to run your CPU at full speed with the Opus.Originally Posted by folagana
Installed.
