Results 1 to 8 of 8
Thread: CHEAPEST way to power an Epia
    Aug 2004
    Houston
    Before anyone says "search", I already did but could not find anything. Here it goes. I just don't have the money for an Opus otherwise, I would definately get one. I don't care about shutdown time and surviving crank. I don't mind pushing a button everytime I get into the car to turn it on. So is it possible for me to just use the 200watt snap on dc-dc power supply? Do I have to use anything else? Thanks in advanced.
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    That snap-on dc-dc isn't regulating the 12v rail, as far as I know, so you'll need a 200w 12v regulator in front of that (as your car can put out more volts, which can damage the computer).
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Cheapest way:
    Run to walmart, spend 20 to 35 dollars on a DC to AC power inverter, and plug your normal computer power supply right into that. Not the most efficent way, probably won't survive crank (Though it might), and you'll have to manually turn it on/off each time. Also might put some noise in the line... If you do this, however, I would recomend running the inverter straight to your car battery instead of using a cig. lighter socket.
    Newbie necrolyte's Avatar
    South Carolina
    Car Power Sequence and Dropout regulator
    Check out this site, hopefully it will be live soon so people can order. I stumbled across it a few days ago working on my car puter. The ITPS looks really good for turning and powering systems.
    http://www.mobilecpu.net/showitem.asp?q=psu&id=5
    Maximum Bitrate Rundell's Avatar
    Quote Originally Posted by necrolyte
    You can get the ITPS from here and its also cheaper!
    http://www.mp3car.com/store/product_...products_id=28
    Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
    GET PAID TO SURF THE INTERNET
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    plug it into your wall!
    BossTone74
    Aug 2004
    Houston
    i guess i am going to go with the inverter route, is it a garantee that i will have line noise with an inverter?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Naw, I've been using an inverter for a few years now. Had line noise at first, but just make sure you ground everything to everything else. That's how I got rid of it. Simple.
    Tidder
    Try RevFE
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  3. High power PSU with shutdown controller
    By lookinco in forum Power Supplies
    Last Post: 08-25-2004, 01:00 AM
  4. Power problems with car computer :(
    By Bitflip in forum General Hardware Discussion
    Last Post: 04-26-2004, 04:13 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
