Results 1 to 2 of 2
Thread: CarTFT Power suply
    CarTFT Power suply
    Hi, I'm new at the forum, and I have used the last month to read about the things you need in a car computer. And I decided to go with an opus, but i Europe I can only find one place that sells it ( ), but they are a bit pricy (280$)
    Buit then I accedently sees that CarTFT (where i'm planing to buy my Xenarc from) got a new DC/DC converter that also survives engine crank.
    Anybody who have an idea about i'ts worth buying, or should i still go after the opus ???
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    I think that the Opus is better because this thing just looks like it has no control. Unless you rig up something that instructs the carputer to hibernate when the key is off. Also, isn't the cigarette lighter unpowered when the key is off? I seem to think that it is. This however is a better solution than using an inverter (I have now) and wall warts plugged into the inverter (one for Lilliput and one for phone charger). Still perhaps Carnetix P-1260 is better than this because it is controlled similar to Opus(whenever it will become available again).
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  3. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
  4. Brief power loss between ACC and start
    By Destin in forum General Hardware Discussion
    Last Post: 01-26-2001, 11:12 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
