Results 1 to 3 of 3
Thread: opus shutdown on power off to hibernate (want either hardware or software solution)
    Aug 2003
    Michigan
    is there a way, with hardware or software, to make the shutdown signal that the opus sends to the mobo a hibernate signal instead?
    i'm guessing the hardware workaround would be messy/unnecessary, and am hoping for an easy software one.
    VIA EPIA 533 MHz
    256 MB RAM
    7" Lilliput VGA Touchscreen
    20 gig HD
    Media Engine 2.1.4
    GPS - Earthmate/SA2004
    802.11b Connectivity
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    There is no distinction. The Opus just pulses the power on/off button on your mainboard. It's up to software to decide what to do. Assuming you're using XP, go into your Power Options control panel and configure windows to hibernate when the power button is pressed.
    Aug 2004
    California
    Alot of Motherboards support a feature such as Standby/Hibernate/Power off when the power button is pressed. The Opus will simply "simulate" the power button being pressed.
  1. Using the OPUS to shutdown other stuff
    By d_sellers1 in forum Newbie
    Last Post: 06-15-2004, 09:49 AM
  2. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
  3. Will a 150W OPUS power this?
    By mbkowns in forum Power Supplies
    Last Post: 04-14-2004, 03:17 PM
  4. Opus 90w Power Action
    By EBoundEE in forum Power Supplies
    Last Post: 03-10-2004, 10:11 PM
  5. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
