Results 1 to 8 of 8
Thread: ITPS with Invertor
    May 2004
    Question ITPS with Invertor
    Alright, i'm afraid i have another question. I have searched for how to use an itps with an invertor, and i haven't found anything. What i want to do is start my car and then have my computer turn on. i'm using a power invertor as it is right now. i've looked on their site, and it seems it's made only for certain kinds of motherboards or something. If anyone has any answers for me, please help. Can i even use an itps with an invertor since i don't have a dc-dc power supply?
    Variable Bitrate euro320i's Avatar
    Apr 2003
    Near Frankfurt
    No.
    Get rid of inverter.
    Use DC-DC converter.
    Take a look at the DOCS for the ITPS, it does exactly what you want, but with a DC-DC powersupply only.
    Good luck.
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    You COULD use the ITPS with an inverter. Bypass the on-board regulation of the ITPS, and use it purely as a startup/shutdown controller.
    However, the best option is a DC-DC power supply.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    use it to control a relay to switch the power to your inverter.
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
    Apr 2003
    Near Frankfurt
    Quote Originally Posted by no1knows
    Hey, that's what the guy upstairs said...
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
    May 2004
    I already have a relay running the invertor, but i don't know how to modify the itps to make it run off the invertor. what pins do i have to change? Where do i insert all the wires? I have a 300 watt power supply on my computer...i don't have enough money to find myself a 300 watt dc-dc power supply, which is why i have my 400 watt invertor. Since the itps plugs into the motherboard, i gotta adjust something don't i? Thanks.
    May 2004
    Try this
    This should work.. YOu want the ITPTS to start and shutdown your computer right? Just hook up the switched +12v cable and the unswitched 12v cable. You won't need anything too powerful. Then just hook up the power button cables to your motherboard. Also you can use the relay you were talking about with the 12v out.
    Apr 2003
    Near Frankfurt
    The ITPS Plugs into the DC-DC converter that powers your mother board. It just to level the 12V supply going into your Mobo.
    Inverter - 12V Adapter brick - PC
    12V from Car - ITPS - (Only the leads from the shutdown controller - Mobo on/off header. You need to hook up the ITPS to 12V Ground and remote power. You're probably want to get some sort of kill switch for your inverter.. don't want to have a flat battery, do we?
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. Voltage issues with ITPS?
    By mcrussell in forum Power Supplies
    Last Post: 06-06-2004, 11:48 PM
  3. ITPS features when using an Invertor
    By no1knows in forum Power Supplies
    Last Post: 05-18-2004, 10:20 AM
  4. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 07:09 AM
  5. ITPS Power Sequence review
    By saito in forum The Review Palace
    Last Post: 12-18-2003, 10:26 AM
