Results 1 to 7 of 7
Thread: 12v Power Supply at MP3Car.com store
    Jun 2000
    NYC
    I did a search and didn't see any write ups yet.
    Also, please no 'Just get an opus' comments.
    200w Snap-On Miniature 12v DC Power Supply for $59.99
    http://www.mp3car.com/store/product_...29a817b694f645
    The last statement listed is:
    Cool power. The PW-200 dc-dc quiet power supply generates a cool 200w of power. The PW-200 provides plenty of power for your CPU and peripherals.
    Designed to meet the most demanding fanless power operations the PS-201 dc-dc converter delivers cool power for ultra compact, light designs. This unit is 100% Silent. The PS-201 mini PSU is a 100% silent dc to dc solution. No fans, no noise, just power for your silent and small PC.
    This unit provides enough power for the Mini-ITX board as well as a hard drive and CDROM drive. Do not use it with a 3.5" HD or CDROM drive without the ITPS regulator.
    Do you think this is a good option if someone would get this Power Supply and the ITPS regulator for $38. Sounds like a $100 dollar option.
    Disclaimer:
    I personally use an inverter hardwired to a switch and to my battery. I'm very happy with it, no noice, no complaints. Buy I'm always looking to see what else is out there.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Trouble is...use the ITPS and it is no longer a 200W supply. It will only supply 200w if the input is unregulated...and if its unregulated it passes the supplied unregulated voltage on the '12V' line. If you want to use it then ther Carnetix is probably a better bet instead of the ITPS.
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    Devices like this are much more useful for robotics than for carpcs.
    Dec 2005
    Quote Originally Posted by pip
    The inlet it's a 12V but do you know how many watts? Because i wanted to test it at home before i put it in the car, and i found a AC to DC 12V 6Watts converter. I was woundering if i could use that to power the power supply...?
    Thx
    Dec 2005
    Quote Originally Posted by KraZThug
    Thx
    NVM I WAS LOOKING AT THE INPUT OF THE TRANSFORMER ITS (12V 200mA OUTPUT) WOULD THIS BE OK TO RUN MY SNAP-ON POWER SUPPLY?
    Elsewhere
    Not even close. You need a lot more than 2/10 of an amp!
    think of it this way: 2/10A X 12v = 2.4w
    Here's something we put together just for you:
    FAQ: Will <insert PSU model> Power Supply work with my system?
    How about the Wiki?
    Dec 2005
    Quote Originally Posted by DarquePervert
    Thx for the great info buddy.
    -Joel
  1. Power Supply Without Opus
    By chewy747 in forum Power Supplies
    Last Post: 09-15-2004, 04:45 AM
  2. DC power supply...HELPPPPPP
    By walid_bmw in forum Power Supplies
    Last Post: 10-02-2003, 02:26 PM
  3. Compaq handheld pc power supply
    By rjstephens in forum Power Supplies
    Last Post: 05-23-2003, 09:26 AM
  4. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 03:19 PM
  5. 12v dc-dc atx power supply
    By plasmadis in forum General Hardware Discussion
    Last Post: 06-28-2000, 05:51 AM
