Results 1 to 2 of 2
Thread: Laptop motherboard PS to ATX motherboard
    Newbie Paddymcc's Avatar
    Ireland
    Ive managed to pull a laptop powersupply from a dodgy unit.
    Ive plugged it into the wall and checked the pins to see what the outputs are which are as follows:
    1 2
    1+20 +20
    2+20 +20
    3 0 0
    4 0 0
    5 0 0
    6 0 +5
    7 0 0
    8 +5 0
    9 +4 0
    10 0 0
    11 0 0
    12 0 0
    13 0 0
    The pins I checked are those with the red box around them.
    Is the power created by this mini board suitable to run an ATX Pentium3 board?
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Besides the difficulty of figuring out the proper connections, which probably can be done, you're almost certainly not going to have enough power. Most laptops run around the 30 - 60 watt range. You maybe can run a stripped down Eden mini-ITX setup, but no way it'll power an ATX P3.
  1. Normal ATX motherboard or mini PC?
    By Spongebob in forum General Hardware Discussion
    Last Post: 08-27-2002, 08:35 PM
  2. Should I switch from DC-DC ATX to laptop?
    By dmbrown73 in forum General Hardware Discussion
    Last Post: 03-05-2002, 01:24 PM
  3. Converting AT PS to ATX PS? How to?
    By Maveric in forum Power Supplies
    Last Post: 08-15-2001, 10:50 AM
  4. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
  5. Noise fix for ATX motherboard
    By smr61 in forum General Hardware Discussion
    Last Post: 03-04-2001, 10:34 PM
