Results 1 to 6 of 6
Thread: AC-DC converter for opus?
    Jun 2004
    Savannah, GA
    I'm gonna be building my system in a aluminum briefcase(same case different seller) and for times when I take it out of my car I was thinking about getting a AC-DC converter. My question is this; would a convertor like this produce enough amperage to run a system? I'm thinking not (90W/12V=7.5A>1), but maybe I'm something isn't clicking. Anyways that was the biggest one I saw on radioshack.com. Will it work anyways since I'm calculating with peak power not actual draw? Does anyone know another source that has adapters putting out more current?
    If I can find one that works I will ditch whatever connector is on the adapter and replace it with a 4pin cb mic plug and connect the male version to the opus. On the connector side I'll short the pins going to the 12v and ign on the opus. I chose this connector over say a 3pin connector because the cb mic plug screws onto the jack.
    90W Opus
    M10000
    256M DDR
    3.5 40G HDD
    Kefka_Killer.owns(you);
    Jan 2003
    Ruston, LA
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    So will this, and it's cheaper and lower profile - though the power supply above would be more useful for other projecting, if you're so inclined.
    http://store.yahoo.com/ituner/ac12v9aswpoa.html
    Jun 2004
    Savannah, GA
    Thanks for the replies, guys.
    Aug 2003
    Michigan
    Just fyi, I use a standard ATX PSU and hook in the 12 volts straight to the opus and it works like a charm. just in case you have a spare one lurking around.
    VIA EPIA 533 MHz
    256 MB RAM
    7" Lilliput VGA Touchscreen
    20 gig HD
    Media Engine 2.1.4
    GPS - Earthmate/SA2004
    802.11b Connectivity
    In a barn
    Talking
    Quote Originally Posted by frodobaggins
    actually there is a 50!!! amp model too. I used to work at radio shack. you have to order it. i think its like $99 or something. a guy i knew used to use em to jump start helicopters so i know they will power an opus or welder.... or your house... either or..
    When in doubt, moo at things.
  1. Possible to turn a DC Toggle switch into AC???
    By Defiler in forum General Hardware Discussion
    Last Post: 07-05-2004, 09:29 PM
  2. DC to DC converter
    By jdub421 in forum Power Supplies
    Last Post: 02-03-2004, 04:17 AM
  3. dc or ac power supply
    By qball008 in forum Power Supplies
    Last Post: 05-16-2002, 11:22 PM
  4. DC -> AC converter question
    By BRINET in forum Power Supplies
    Last Post: 03-25-2002, 03:21 PM
  5. Need help finding an AC to DC power adaptor
    By Squeezer in forum General Hardware Discussion
    Last Post: 12-29-2000, 01:27 PM
