Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 60
Thread: you dont necessarily need a voltage regulated PSU
  1. #21
    Maximum Bitrate none's Avatar
    Sep 2003
    This is called a tank circuit. Many members here have used them with great success, some even using a battery isolator rather than the cheaper diode. The specifics of the circuit don't matter (some have even had success with capacitors instead of batteries), it is still called a tank. Usually they are intended to smooth out voltage dips, but can also be effective against voltage spikes (depending on isolator, but not as safe as a voltage regulator in this regard.)
  2. #22
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    Quote Originally Posted by MatrixPC
    I "think" this is what he use.
    - el cheapo snap-on style DC-DC PSU (unregulated 12V line) that some of you guys use with VIA mobo and laptop HD, CD/DVD ROM.
    From what i can gather, think PW120/PW200
  3. #23
    Constant Bitrate GWRedDragon's Avatar
    Aug 2004
    Arlington, VA
    Quote Originally Posted by The Grinch
    This is a nice solution unless you're like me and ocassionally run a mission critical app. My setup could use an extra battery though.
    What's mission critical in your carpc? Do you use it to set the cruise control or detect collisions or something?
  4. #24
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    Quote Originally Posted by GWRedDragon
    I have a OBDII programmer. A PC failure during the write phase would render the PCM (or ECM if you prefer) useless and the car would no longer start.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
  5. #25
    Newbie popuptoaster's Avatar
    Aug 2004
    Essex, UK
    I understand all of the idea behind this system, i have been running my ICE like it for years, but im not sure what this "snap on psu" is, anyone post a link so i can have a look please?
  6. #26
    Aug 2003
  7. #27
    Aug 2004
    Essex, UK
    sweet, thanks, that can be used on a full sized descktop pc too?
  8. #28
    Aug 2003
    hmmm.
    depends on whats in that pc. Also, as it is snapon- you may have to get creative with your wiring to run a hdd.
  9. #29
    Aug 2004
    Essex, UK
    should be fairly low powered, im hoping to pick up something "out of date" for virtually nothing which is why im going for a full size one, as i dont have any room constraints.
    be running a 5.1 sound card and a WiFi card along with a DVD drive, so hopefully it should cope.
    I dont understand the creative wiring bit? Im handy withy a soldering iron, but not so hot on actuall electronics theory.
  10. #30
    I am also confused how the +12V can be a "smooth 12V". Is this only when the car is off? The alternator does not charge at 12V. If the the alternator is connected to the battery, which is connected to the PS it will also be at the alternator potential.
  1. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  2. setting up a regulated psu
    By RogerWilco in forum Newbie
    Last Post: 08-21-2004, 07:12 PM
  3. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  4. 12v/5v regulated psu?
    By etrik in forum Power Supplies
    Last Post: 08-12-2002, 04:00 AM
  5. need negative voltage to power PSU
    By l4tran in forum Power Supplies
    Last Post: 05-11-2002, 10:40 AM
