Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 53
Thread: I've soldered in my relay 4 different ways and it still won't work. Help please.
  1. #11
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I'm tellin' ya man, check your coil ground. I really don't think it will work that way. C'mon, PROVE ME WRONG.
    Edit:
    Haha, just noticed this:
    Quote Originally Posted by wonderworm
    Maybe my ground is wrong since it is going to the 3rd prong (ground) of the ac plug.
    Try hooking it to a normal ground.
    Tidder
    Try RevFE
  2. #12
    Low Bitrate Shayughul's Avatar
    Jul 2004
    Minot, ND
    First, the relay should only allow the on/off switch to receive power when the ignition is on. Then, my on/off switch also has to be in the on position to turn on the Inverter.
    Ok...I must be thick....if you just left the on/off switch on the inverter alone wouldn't it already function this way? I mean on is on...why do you need to add a relay to make it do as it already does....
    sorry if I am being thick about this....but it just seems pointless to me. Just use the switch that is there.....I mean you could just leave it in the on position and then the inverter would always turn on when the other relay provides power?
  3. #13
    Low Bitrate wonderworm's Avatar
    Jan 2004
    Quote Originally Posted by Tidder
    Actually it would be proving you right. I'm soldering a longer ground wire right now to ground to the chassis. This relay will be done, and if some people can't comprehend what i'm trying to do, then they need to quit talking so much and listen more.
  4. #14
    Jul 2004
    Minot, ND
    Heh....sounds good to me....Burnout 3 is calling my name anyways....good luck
  5. #15
    Jan 2004
    UPDATE:
    Changing my relay's ground to the chassis allowed the Inverter to boot up when turning on the Ignition. Sooooo...........success!...............almost.
    However, when I plugged the pc in, the red overload light comes on and the PC turns off after attempting to boot.
    So I'm thinking my problem now could be as follows:
    When I originally hooked up the relay's ground coil to the AC third prong (ground) plug, I heard several beeps, and then my inverter shutoff completely. Fuses were still intact but maybe I smoked something in the inverter or otherwise messed it up.
    I could test this by re-checking all of my contact points for a solid connection or completely removing the relay and seeing if the 400 watt inverter can boot the computer under default specs (I'd like to try this last).
    If anyone has input before I do this, feel free.
  6. #16
    Variable Bitrate vcbb5's Avatar
    Aug 2002
    Kansas
    I haven't read this entire thread but for a good shutdown control of an inverter i use this diagram:
    and the little software prog in this thread:
    New shutdown controller - software
    and here is another thread with more info:
    Ghetto Startup/Shutdown Control for Inverter
    instead of wireing the relay directly to battery power cord of inverter, i used the switch (easier, less power demands, and works perfect), but it does require opening the inverter (really not hard). The only thing bad about the setup is that the inverter shuts off ONLY AFTER the computer shuts down, so if you have a pos that hangs, your inverter could potentially be left off (but it should be stable when only useing solid software like carputer stuff).
    My Mazda 3s
    My Mazda 3s on Car Domain
    [||||||||||||||||||--] (90%)
  7. #17
    Sep 2003
    New Mexico, USA
    UPDATE:
    Sweet. When you say test under default specs, what are you talkin' about?
    Tidder
    Try RevFE
  8. #18
    Aug 2002
    Kansas
    Sweet.
    If you want i can post some pics of the wires (i don't have my carputer installed, but the wires are in the car). I actually wired them from a little plastic holder thing to a phone cord and than to the back of my computer, and it works great.
    My Mazda 3s
  9. #19
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by vcbb5
    I haven't read this entire post but for a good shutdown control of an inverter i use this diagram:
    It's easier with a cube timer hooked to the relay and power switch header instead of trying to hook a relay to the com port and using some crazy software.
    Tidder
    Try RevFE
  10. #20
    Sep 2003
    New Mexico, USA
    I'd like to see for sure man, cause actually cube timers are expensive...
    Tidder
    Try RevFE
